Old 07-20-2012, 08:55 PM
Originally Posted by Rlbol View Post
Thanks guys
So 20degree is the correct angle for a 23 center console?
If any one has pictures of where there's is mounted could you post them?
Mine is Airmar tilted element. I think it's 20*
Old 07-20-2012, 09:13 PM
WildBill WildBill is offline
The 20 degree's is the angle of the cone pointing toward's the sea bottom. The 20 degree transducer is a narrow angle beam or narrow cone. You would use a wider beam in shallower waters. The narrower the beam or cone the more concentrated the signal so therefore the deeper it will see. The question should be what are you using it for? I had a dual switch on my lowrance with a wide angle transducer and a narrow angle 20 degree thru hull transducer. I mainly used the stock wide angle dual frequancy transducer that came with the unit it fished great up to about 300'.
Old 07-23-2012, 03:58 AM
Rlbol Rlbol is offline
[QUOTE=reelescape1;205570]Mine is Airmar tilted element. I think it's 20*
Thank you
I did recieve the tilted 20* airmar.
So now where to drill the hole!!
Reelescape thanks for the pictures. Do you have any that would show the location?
I am trying to figure out as far as which step and how far aft. I am replacing the current bracket with a hermco larger twin bracket so I am not sure it would matter much with the engine mounted farther aft.
Old 07-23-2012, 08:50 AM
You are correct, the transducer will not affect the engine. It's only a 1/4" deep. Mine is centered on the first step from the keel, starboard side, just about 8" in front of the bait well. In your case I'm assuming the bait well is not going to be there. Install close to the transom where it will be out of the way in the bilge, you know, like if you need to step down into the bilge you do not want to step on the transducer or cables. Take your time when installing, it's a one time, get it perfect deal. Good luck!
Old 08-04-2012, 03:23 PM
Thank you
So it is getting close to big hole drilling time. Any last minute tips or advice?
On another transducer question. There is an exsisting through hull ducer mounted directly in th center of the keel. Looks like an oval size not any wider then the keel and about 6 inches long. It is mounted what looks like under the leaning post aft of the console. The current configuration of my boat is the fuel tank is from the rear of the console all the way forward to flush with the step up on the bow. Then there is a large fish box flush in the floor between the strings. It sits just aft of the console ending aft of the leaning post. I assume this is the compartment normally in front of the console in the floor? I am not to sure how you would access the old transducer for in the hull? I never noticed it before due to it location being so far forward and it being painted over with bottom paint. I have thought about calling airman and seeing if they make a transducer that would fit and replace that one in the center of the keel with the new transducers for the chirp fish finders then install the 21* for the regular fish finder? Or would it just be best to remove the old one? If so what would the best way to go about filling such a large hole in the keel?
Sorry for rambling on as always thinks of all the great advise!!
