Old 03-09-2013, 12:19 AM
Originally Posted by cjm1300 View Post
. . . and i am looking for good fuel economy but still speed. Again thanks
Then look at an Optimax or E-Tec that will have similar fuel consumption to a 4 stroke (> 4 mpg) but are much stronger on mid-range torque and power/wt. The Zuke 140 at 421 lbs (before you put 11 pounds of oil in it) is relatively light for a 4-stroke and the only one I'd even consider and would probably get you about 40 mph. However the small block 2.7L V-6 E-Tec at 433 lbs is a much stronger motor. The 150 is actually 165 at the prop with tons of mid-range torque and should give you mid to upper 40's. The 175 & 200 may have a little less mid-range torque, but should have enough top end power to put you over 50 mph.
Old 03-09-2013, 10:11 AM
Yam hpdi 200 weighs around what a 140 4 stroke zuke is, way more power and fuel burn is good, just burns more oil...
Old 03-09-2013, 08:47 PM
I have a old 91 150hp evinrude and it fine till my fat azz steps to the back
82 seacraft 20SF
Bayview Canvas
Old 03-10-2013, 08:19 PM
cjm1300 cjm1300 is offline
I don't mind the water coming in as long as it does not come over the transom. Its Florida i don't mind wet feet lol
Old 03-19-2013, 09:41 AM
jwclbi jwclbi is offline
I have a 225 efi merc weighing in at 475 and when I'm in the back of the boat a little water fills the drains but none on the deck. And like you cjm1300 I too love the speed!
Old 03-19-2013, 09:47 AM
your NEW option is the new Yamaha 200 4 stroke... it is built on the 4 cylinder so it weighs roughly the same as the 150 4 stroke.. BUT you will have to PAY for the NEW motor... I'm sure they arent giving them away..
RUSTY PARKER
Old 03-19-2013, 01:46 PM
My stats:
Lots of bottom paint
366lb 4 stroke 100HP
Plus
60 lb kicker
Plus a under prop fin and 4 blade prop for more lift but more drag
34 MPH
5-6MPG (I run a 20 gallon tank- no need for more)
12 knot/14MPH planing speed
With no fin and a different prop(12.75 x 17) and no kicker I think 37MPH could be had, maybe 38 with a SS prop and no bottom paint, albeit with a higher minimum planing speed.
I don't need trim tabs.
Just a data point. I spent a lot of time and a little money on props and fins to get the best out of a light low power outboard. I don't even have a stainless prop, so if 40 MPH is your goal, there might be a light weight efficient way to get there with something like an Etec 115 or 130?
Old 03-21-2013, 05:11 PM
BrianS BrianS is offline
I have a 1973 20sf all redone w/150 etch very happy performance 43 mph with 2 good size people aboard
Old 03-22-2013, 02:59 PM
Mark Mark is offline
Originally Posted by PigSticker View Post
I saw an 87 20ft with a four stroke 150 on the transom and it had water coming in the drains with no one in the boat
My 20' did that with a 2-stroke 135 on it. They are SeaCrafts, they ride too low in the water for where the original deck is (which is why some of us that have had them redone raise the deck - to FINALLY have dry ankles). Sadly, Tracker/BPS didn't remedy this when they built them either, the Lefty Kreh "Master Angler" will suck water in the scuppers when sitting at the dock if you step in it. Great design, huh?!
Old 03-22-2013, 03:14 PM
the 150 Etec is one of the strongest ponies out there, seems they maxed the allowed 10% allowence on HP - even compared to their other motors
having water come in with no one in the boat with a 135 2 stroke the boat had other issues, nobody with V6's have that issue, mine won't, full of fuel and the baitwell full and a T top
