Old 04-26-2013, 06:29 AM
hermco hermco is offline
Get a bunch of shop rags and use them blue shop towels won't hold up
Ding.
Old 04-26-2013, 07:34 AM
erebus erebus is offline
I also recommend doubling up on the nitrile/latex gloves.
Put on two pairs that way when your up to your elbows in 5200 and your phone rings/need to scratch/drop something/need to operate a doorknob, you can take off one glove and not have to try and put new ones back on.
I don't know what it is with 5200 (and anti-seize for that matter) but I swear you only need a teaspoon and you could cover the whole county.
Zachary
Old 04-26-2013, 08:18 AM
Make sure you tape everything! I think I used 4 tubes and I think most of it squeezes out. I remember bolting up fairly tight. Cleaning up the mess of 5200. Then pulling all tape. Then bolting up really tight (after a partial cure) and running a finishing bead of 5200 to make a nice radius.
Break a Leg
1974 23SF
Old 04-26-2013, 08:32 AM
A rubber squeegee (the best) or plastic spreader cut to about 3" wide works well for removing the excess.
Old 04-26-2013, 12:00 PM
jongolds jongolds is offline
Glad to hear mineral spirits are the preferred solvent. That I have on hand. To be clear, the bracket is already installed, I'm just putting on a sealing/finishing bead in hopes of eliminating a mysterious slow leak that fills the bracket every summer. I am assuming a single tube should be enough. That's all I bought. Would I be wise to grab more before geting started?
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 04-26-2013, 07:36 PM
One tube will do it.
Old 04-27-2013, 07:45 AM
Seacret Weapon Seacret Weapon is offline
Ain't that the truth.
I like to use a tongue depressor to smooth caulk. Pack of 100 from a craft store is about $2.00.
Old 04-28-2013, 02:12 AM
aj1976 aj1976 is offline
Mineral spirits better then acetone!
Old 04-30-2013, 11:12 AM
all went well with this project this weekend. I'm hoping to get it in the water next weekend. Hopefully this cures the leaking issue. Thanks for all the advice.
Norwalk, CT
Old 05-04-2013, 11:42 AM
I never use 5200. at some time that bracket will come off. then the swearing starts. been there done that on transducers below waterline. I use 4200. or life caulk. its done now hope it solves the issue.
275(chipped 250!) Verado
Merc Rev 4 17P
