Old 07-15-2013, 03:11 PM
cdavisdb cdavisdb is offline
Passing everything but the gas dock sounds about right. It all depends on what you want to give up for the speed. The boat will balance better with the small block. It likes weight forward, a lot, and, like Denny said, the big block does the opposite.
If you went for a big block, or twin 6 cylinders, some permanent weight in the bow might be a good idea.
Just a thought, I run with a `4 cycle kicker and a big dive platform with lots of storage (and weight). The duoprop adds weight way back there. In terms of CG, mine might not be too different from a big block.
Old 07-15-2013, 04:55 PM
Denny,
I haven't had the hatch off yet but I'm willing to bet the tank is original. I'm sure it has baffles but she definitely sloshes. Another point is, our hatch goes all the way from engine box to the step down, instead of half way like most others, in order to accept the 100 gal tank. I think the twin 50's are a better option for controlling the forward weight.
Gerry,
Although he hasn't posted in quite some time, forum member Ken Kurek has a 454 in his 25. You could try shooting him a PM for some more info on the big block.
Brandon
Old 07-15-2013, 05:09 PM
GERRY GERRY is offline
thanks for all the responses! I will keep you updated when I purchase.
Old 07-15-2013, 07:08 PM
Food for thought.
She is a drivers boat.
http://www.classicseacraft.com/commu...=24536&page=22
Old 07-15-2013, 09:13 PM
Food for thought.
Sandy is right. This is not a boat for someone who doesn't have a good grasp of the physics of boat handling and a desire to use that knowledge to optimize his seamanship. I was a little startled by the amount of heel in a turn when I first launched mine, but now that I'm used to it, it's kind of fun to play with. I can lay her over in a turn until you feel like you could dip your fingers in the spray off the chine from the helm seat, or I can add reverse tab and make sharp turns without banking into the turn at all.
I don't mind using the tabs to keep her running level, but it's not necessary unless there's someone moving around the boat. Connor is right about the heel response to minor turns of the wheel and how that makes it easy to land on the next wave the way you want to. Definitely a driver's boat, and about as nimble as you'll find in a boat of this size.
All that being said, I agree with pretty much everything the other 25 Seafari owners have said. I think the 5.7 MPI Mercruiser or Volvo Penta is the right power for the boat. I have the 350 Mag MPI and a Bravo 1 drive and can cruise comfortably at 30-33mph with a top speed of 40-43mph depending on propping and load, and a minimum planing speed of about 13 mph.
The Bravo 1 does produce a little torque heel out of the hole, but it goes away once you get on plane and trim the outdrive up a little. I would like to move to the counter-rotating Bravo 3 , but it's hard to justify the cost when the Bravo 1 works just fine.
Dave
Blue Heron Boat Works
Old 07-16-2013, 11:58 AM
The 7 ft berths are perfect for tall guys. Excellent sitting down head room in the cabin. Its extremely comfortable for two. My wife and I do 3-4 day trips, just fine. I do longer, diving trips with 3, one (me) sleeping on the deck, which works great if you set it up right.
Old 07-16-2013, 12:25 PM
GERRY,
Heres a link to one of Conner's recent adventures showing part ofthe inhabited cuddy:
http://www.classicseacraft.com/commu...davisdb&page=2
Old 07-16-2013, 03:29 PM
thanks. One more question. Are the scuppers in the seafari 25 the same arrangement as a seacraft 23?
Old 07-16-2013, 04:13 PM
bilgerat bilgerat is offline
the floor drains out the sides of the boat on the 25
Old 07-16-2013, 04:24 PM
thanks! Gerard
