Old 09-08-2013, 02:42 PM
prre and post air filtration !!!!!! no rustoleum paint... it sux !! they send us that crap out here and it peels off after a few months in the salt environment ... I would find a good high temp epoxy...
RUSTY PARKER
Old 09-08-2013, 05:16 PM
What kind of filters? Who makes good hi temp epoxy paint?
Would a 5 gal tank have a benefit over 3 gal.?
http://www.ebay.com/itm/3-Gallon-Alu...e36bf8&vxp=mtr
http://www.ebay.com/itm/5-Gallon-5-P...6a7dff&vxp=mtr
Old 09-08-2013, 07:58 PM
as large a tank as you want to carry... the larger the tank the longer the uh ho time... as for the high temp paint look for something like a tractor / commercial engine paint... it would be designed for prolonged outdoor / sun exposure due to its intended use... as for the filter .. i'd have to do some mining on the internet... i have been looking for a pink camoflage welding shield as of late for my daughter... she is taking welding classes and her mother told her if she was in the top of the class and made all A's and B's we would buy her what she wanted..... little did my wife know that it would have to be custom made.... but if anyone comes across one let me know....
quick search brought up this one..
https://www.filtertechs.com/shop/pro...61738de6dab794
the inlet filter is more or less a dust filter...
the tanks are cool !! just put a valve on each port and a quick connect and add hoses as needed !!!!
RUSTY PARKER
Old 09-08-2013, 09:15 PM
http://compare.ebay.com/like/2611804...Types&var=sbar
http://compare.ebay.com/like/2212254...Types&var=sbar
Old 09-08-2013, 09:23 PM
Sandy....
"Cracker Air" has successfully provided thousands of hours of good air supply without any storage tank!!
With 100 ft. of hose out you can feel the vibration stop through the
hose if the gas engine stops for what ever reason.....
When that happens it is time to come up!!
Was at 60 ft.. engine stopped!! Made my way back up slow and easy
with enough air in the line...
If you like, carry a "Spare Air" if diving more than 65 ft..
I do !!!
As far as paint goes high temp engine (Ford Blue for you)
or BBQ grill paint will do just fine..
As far as filters, I use the filters that are stock with the Gast pump..
About $25 a piece... I use two for the PCA10 Gast....
Keep it simple Sam!!
Old 09-08-2013, 09:37 PM
Copper Collar Copper Collar is offline
What MMP are you guys pushing to your regulators? Are these oil less compressors?
Old 09-08-2013, 10:14 PM
Even Kevorkian contraptions are oil less. I`ve graduated from 110v on a boat.
Ran outta air on snuba in 20 ft. No big deal. I have a spare Octo I will part in. As I camp, so shall I dive. Simple and light. I do carry a lot of sandbags on my belt for a squid weight.
Cheers,
GFS
Old 09-08-2013, 10:26 PM
Blows off at 60 lbs... Sherwood regulators designed for a Hookah..
Yes they are oil less compressors...
Just went out to the man cave and snap a few current rehabbed pics
of my beloved 'Cracker Air"
This is the same one in gfs's post with Denny, Skip & Carla!!
20 years of faithful service!!
Old 09-08-2013, 10:45 PM
. . . who makes good hi temp epoxy paint?
Sandy - check out POR-15 http://www.advanced-rust-protection.com/por15info.htm
A friend of mine that's a Professional Engineer who runs a consulting business specializing in restoration of reinforced concrete buildings/oceanfront condo's specified it for protecting the cables in post-tension buildings. (These are cables installed in the slabs of high rise buildings that are stretched to keep the concrete in tension after it cures. If the cables rust thru, it's a serious problem!) I used it on the floorboards of the old 'Cuda I'm restoring. The guy who painted it that does professional show car restorations is so impressed with it that he's now using it also. It's very tough stuff. They've coated a rusty brake drum with it, and were unable to chip it with a ball peen hammer! The only downside to it is that it won't tolerate UV, so it needs a topcoat if it's exposed to the sun. Denny
Old 09-09-2013, 10:50 AM
bitsamonkey bitsamonkey is offline
I would go with the 5 gallon aluminum tank. Make sure you mount it in a way that positions one of the ports at the bottom of the tank so you can drain it. Any filters are really just to protect the bore of the compressor and there isn't any dust to speak of out on the water. I'd skip the filter as it's just going to get wet and soak up water. It's nice to have a baffle in the intake tube to cut down on the noise and a snorkel to keep out water. I made mine extra long to keep it in the fresh air and avoid sucking up any CO. If you mount a muffler you can point it up at an angle and get it to blow most of the exhaust over the gunwale. I run a 100' hose to a tee and then two 50' hoses to the regs. I use small outside diameter hose as there is significant drag on the hose itself in any current.
