Old 07-14-2014, 06:56 PM
Try Farco plastics in lauderdale (954)486-7660. there west of power line and south of 62nd.1305 nw 65 place
Old 07-15-2014, 03:30 PM
YeA 20sF YeA 20sF is offline
yea I found them yesterday on craigslist. Gave me a pretty good price on a full sheet thanks for the info.....
I made this for my truck yesterday but I feel its a tad bit to big....
So i changed it up today, think these will be better.
Old 07-15-2014, 05:42 PM
they used to have cut offs from larger projects they would sell kinda a hit or miss deal but if you needed a smaller pc for a project they might be able to help others as well I needed a pc of 1" blk and they had a 1'x1' pc they helped me out with quite a while ago
Old 07-16-2014, 09:59 AM
Alright guys I have a big question. When I bought the boat the seller told me he keep the gas tank empty and would run the engine from an external tank since it was parked. But once I got it home I see that the gauge has a switch and once switched on the gauge reads that there is something in the tank and it does smell like there is something in there. Here is the kicker, there is no hatch to get to the tank. I would literal have to remove the console to remove the entire tank hatch (Middle part of the floor) I really don't want to do that just yet. But I don't want to risk putting gas in the tank without knowing whats in there or the condition. Is there a way to remove whats inside the tank without needing to remove the console ? Or am I just better off going through the console removal process ?
Old 07-16-2014, 11:23 AM
If you have the $$$$$$, pull it, inspect it, go from there
Old 07-16-2014, 01:05 PM
Originally Posted by Lordwrench View Post
disconnect the feed line going into the water separator (if you have one installed) and get a cheap siphon starter hand pump,it's like a little bellows looking thing.You can just bleed it all out of the line that feeds the engine.I would want to see the tank really, but more important remove it to clean the inside.If it's foamed in which is likely, it's a moot point and I would drain it from the tube and fill it and drain it agian.
B
I would prefer to try an empty the tank see what comes out. If it looks bad bad then yea I would remove the console and go through that process. But if not then heck I'm out on the water next week.
Old 07-18-2014, 11:53 AM
Question the throttle that came on my boat is original style left handed(i'm guessing thats original style) but I'm use to the right hand throttle. Can I flip this around or do I have to get a right hand specific throttle ?.....
Old 07-22-2014, 11:55 AM
Making small progress on this old gal....
My steering was stuck turned out to be that the actual motor was pretty much stuck from just sitting. Added some grease and torch got it to me pretty freely. but my steering box is busted. Removed that ugly ass old "T-Top" and the bow railings, now just gotta find some teak and starboard to add to some of the soft areas to get me through this summer. Also working with some Acrylic on my new dash piece where I plan on adding some new gauges and switches.
New style i'll be cutting today
Still need an answer on the throttle question....... The throttle that came on my boat is original style left handed(i'm guessing thats original style) but I'm use to the right hand throttle. Can I flip this around or do I have to get a right hand specific throttle ?.....
Old 07-22-2014, 12:23 PM
FLexpat FLexpat is offline
I am pretty sure it is reversible - it looks like the same one that is RH mounted on mine and I have a dim memory of getting a shift cable hooked up wrong and being surprised at the dock (fwd instead of reverse). I think it was that one so it makes me think they are reversible.
Old 07-22-2014, 12:29 PM
They are reversible. You will just need to change some linkage around on the inside.
