![]() Quote:
http://www.boatbuildercentral.com/ ![]() my rebuild thread: http://www.classicseacraft.com/commu...ad.php?t=22090 |
Is the handle not engaging or is it turning with the motor?
There are four Allen head screws in that ss sleeve next to the handle; loosen them and the handle will come off. There is a pin in the end that engages the the low gear; pull it out and make sure it's clean and no salt on it. Hope this helps, but it's a fairly simple system. You can always call Zsolt at Dolphin reels in Bradenton, FL. |
![]() Quote:
Don't tighten the Allen screws too much, otherwise the handle will spin when you engage the electric drive.
Also the screws sit between the two channels on the drive shaft so the handle doesn't fall off. You have to find the screws happy spot! |
