Old 01-05-2015, 10:28 PM
Default Boat structures 101
Some recent posts, and the broad range of approaches to boat restoration we see here, got me thinking it might be nice to have a “go to” resource on ClassicSeacraft.com for folks looking to fix up their boats. A lot of us, myself included, are amateurs looking to restore classic boats to their former greatness.
And make no mistake, these are great boats. Seacraft was among the early pioneers to go with structural fiberglass stringers without wood cores. They were using the highest quality cores available at the time for decks and transoms, end grain balsa, and marine plywood respectively. With the endless array of composite materials and advanced resin formulas available today, the choices can be staggering.
I hope this thread will encourage a discussion of the available options for restoring these boats without getting into a debate over what is the “best” way to do it. Ultimately, all decisions are a compromise. Cost, availability of materials, and skill level, all enter into the equation. What’s best for me may not be best for you. Let’s make this thread a discussion of the tradeoffs that come with our preferred method. We have quite a few professionals on this site, and without naming names, I hope they will contribute to this thread. Especially, I hope they will correct us amateurs if we post something that’s wrong.
Before you can make informed decisions about what materials to use, you have to have a basic understanding of boat structures, so that’s where I want to start. Fiberglass boats are made up of some pretty simple structures. There are solid laminates, like the bottom and sides of the hull. There are cored laminates like the deck, gunwale cap, and transom. And there are structural members like stringers and bulkheads which may or may not be cored.
The solid laminates used from the keel to the sheer line in our boats serve several purposes. They resist the bending forces imposed by hydrodynamic loading (a fancy term for water pressure) at planning speeds. They also protect against impact and puncture when we run over something we wish we hadn’t in the water. Assuming a reasonable spacing of stringers and bulkheads in the hull, a solid laminate (in boats the size of our Seacrafts) is going to provide the best puncture and impact resistance when it is sized correctly to resist the bending forces imposed on the hull by water pressure at planning speeds.
The deck, gunwale cap, transom, and parts of the console are made from cored laminates. Cored laminates are probably the most misunderstood structural element of our boats. Many of us think the core is what provides the strength while the fiberglass “coating” protects the core from rot. That is simply not how a cored laminate works. There are some good resources online to explain how cored laminates work. I found one here that does a very good job of explaining the function of the outer laminate and the core in terms of the loads they resist:
http://www.oneoceankayaks.com/Sandcore.htm
In a nutshell, a cored laminate works the same way as an I-beam, what the structural engineers call a wide flange section. An I-beam has three basic elements, the top flange, the bottom flange, and the web. Remember these terms for later in this post. In an I-beam supported at the ends, bending loads create compression forces in the top flange, tension forces in the bottom flange, and shear forces in the web. Why?
The best way I can think to paint a mental picture is this: Imagine if you take three 10 foot 1 x 8 boards and stack them flat on top of one another between two saw horses. Now, take your fattest friend and ask him or her to sit on the stacked boards right in the middle. Depending on how big your friend is, they will either deflect dramatically (anything more than a third of an inch in a 10 foot span would be considered too much) or they will fail completely and your friend will find him/herself sitting on a pile of splinters. Why?
Partly, because the boards are able to slide against one another. And partly because we didn’t take advantage of the shape of the boards and stand them on their edges. More on that in a moment (pun to follow).
Now, imagine taking the same three 1x 8s and glue and screw them together to make an I-beam. You can probably seat two of your fattest friends in the middle of the span without unacceptable deflection. Why?
The answer is a concept called moment of inertia. It’s a complicated concept measured in Inches to the fourth power, (at least here in the good old US of A) and well beyond the scope of this thread or even my ability to explain it. The Cliff’s notes version is this: When you have a beam or a panel that is intended to resist bending forces, the bits farthest from the bending axis (the flanges) are doing the most work. The middle bits (the web) are resisting the shear forces that want to make the flanges slide against one another like our stacked 1 x 10s. Since the shear forces exerted on the web of our beam, or the core of our panel are much lower than the compressive and tensile forces on the flanges, the most economical structure is composed of flanges with high tensile/compressive strength spaced as far apart as practical by a web or core just strong enough to resist the lower shear loads. Are you with me so far?
Translating this into practical terms, a deck made up of two layers of fiberglass laminate, separated by a core of end grain balsa (which has almost no ability to resist bending loads on its own, but has exceptional resistance to shear), creates a very strong lightweight structure with excellent impact resistance and durability in a marine environment.
Enough food for thought for now. Please feel free to chime in with questions or input of your own. I’ll post more as I think of it or in response to your feedback.
Blue Heron Boat Works
