Old 04-21-2015, 12:04 PM
Originally Posted by Duckin20 View Post
. . . I can also get my hands on a 125merc and like I said that 115 etec, do you think I should go with one of those no matter what? . . . .
Either would be plenty of power for what you want to do. Don't know if the merc would be lighter, but there is a great E-TEC forum that's similar in quality to this CSC forum and supported by some very good factory trained techs that would be a big factor in my decision!
Old 04-22-2015, 09:50 PM
Totally agree with Bushwacker on the 20 . . . Those large heavy motors (3.0L+ 250hp) will destroy a stock 20 seacraft in short order unless it's been beefed up and overbuilt. IMO the 20 seacraft shines at 18 - 22mph in rough water and a 27 - 30 cruise in calm water / light chop. With a light motor and good weight distribution the hull will dance and surf. With a heavy 500+lb beast the hull will drag azz around doing wheelies and never ride right. You might be able to hit 55+ WOT but it won't hold together very long . . . Just my opinion.
I had to stuff the bow more than a few times at high speed to figure this out.
Old 04-22-2015, 10:38 PM
htillman htillman is offline
Had friend with a 250 Johnson on a 20 that boat was over powered, fast squirrely and stern heavy. Got rid of it and went to a black max. Still fast, probably faster but not as heavy or squirrelly. I have a 150 etec on my 20. Still trying to get her dialed in but went from a rebel prop to a viper and changed the performance dramatically. No longer porpoises and is much quicker. Still think it is a lot of motor for the boat
Old 04-23-2015, 07:23 AM
I am taking the heavy 3.0 225 mercury off of my 20 and going to a lighter slightly hoped up 2.5 block. It will get me under 400 lbs and about the same hp but I will loose a little toque. But I couldn't use that any how. 20's don't need that much power to preform, I just like going fast and with the weight forward on my sceptre I can get by with it but on a cc hull it don't need the weight
Old 05-15-2015, 07:35 PM
Duckin20 Duckin20 is offline
ended up with a 2010 175 etec will post photos tomorrow, shes mounted up now the rigging begins!
Old 05-16-2015, 07:47 AM
I moved this thread to the Performance section.
DonV
Old 05-16-2015, 11:08 AM
Old 05-16-2015, 06:02 PM
yer probably gonna want a big four-blade stern-lifting prop, but that sucker is gonna fly...
Old 05-20-2015, 06:57 PM
Ditto on the 4B prop needed. Think stern-lift. You'll need to get REAL familiar with working the trim tabs, too. But with those things addressed, you'll be pleasantly surprised at what a wonderful boat you've put together.
Old 05-23-2015, 08:27 PM
Im MORE than excited! i just returned from the first time getting her in the water, You all are very correct she sits low and ill definitely be needing something for my transom, I got her (according to my iphone gps) to 65 at 4800 rpm, It handled as expexted but this has been a two year process and more then happy with how she came out thank you to everyone especially bushwacker ( for the emails) for all of the advice
