I will order a new water tube seal for the port side engine. Hopefully I can install it from the bottom up.
I love this forum. Thanks to all for all the help I've received! |
![]() Quote:
The water tube is just 1/2 copper pipe . . . you can make your own. It does not drop when you pull the lower. Be careful no to destroy the upper water tube grommet when you install the new water tube. Tstats don't open on that motor until block temp reaches 143 degrees. You won't get much out the tell tale until tstats open. Running on a hose it can take 3 - 4 minutes before they open up and only then you'll get a steady stream out the tell tale. You can test your tstats on the stove in a pot of water. Make sure they open @ 143 degrees. You can get a infrared temp gun at harbor freight for about $30. Worth every penny. http://www.harborfreight.com/non-con...9465-8905.html |
Thank you. I never thought about the outboards having a Tstat. I ordered 2 new upper water tube seals. Hopefully the starboard side seal is ok and that I can install the port side from the bottom-up with the new water tube.
Hopefully this will help you visually see the flow through the block. Save those upper water tube seals for your water pump housing . . . If you want to get at the upper water tube seal, you have to pull the power head and adapter plate to replace it. That's a difficult task on 30 year old saltwater motors
Makes sense. I should have thought about Tstats because they are water cooled. Senior moment I guess. Now to figure out why the port engine has water flow immediately when started. Maybe Tstat is stuck open?
yes, It must be stuck open or there is not one in there. The mercury t-stats open up at 143 degrees and you will not have any flow out the tel-tel till it reaches that temp then it will open and you will get some flow. A lot of the time the water on the muffs coming from a water main is so cold that running a merc on the muffs the t-stats will never open. The best way to check them is to put them in a pot on the stove in water with a thermometer and heat them up and make sure they open and close. They only cost $10 each so I change mine bi yearly with the water pump impeller.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
