Old 08-11-2016, 11:46 AM
Greetings Dogbomb,
Got plenty of those in my backyard, and could use a whole bunch down at the Coronados... but I digress...
Congrats on the the Seafari. I too, had a SeaCraft hauled sight unseen from the other side of the Big Muddy. Pretty sure its some kind of unrecognized disorder.
At any rate, I'm sure Capt Terry and Bushwacker have already mentioned what a versatile little boat it is (see pic below).
A couple of things to note:
Scuppers tend to leak. They probably need replacing and are about & 5 ea., online. Moeller also has a flaring tool for about $35. These scuppers are very efficient underway, but not at the ramp or sitting still.
The scuppers corrode/crack over the years and water seeps in around them saturating the wood blockthat surounds/supports them, and then nature takes over. Usually visible along starboard string by batter pad if you're looking for it.
The other leak tendency is at the seam between the hull and cap. This will saturate the cabin and eventually you'll have a wet sleeping bag on a cold night @ Lake Powell or Havasu.
Addressing those two things are easy and offer some peace of mind.
Great boat for your plans. BTW did you ever look at the Yellow Seafari 20 listed in Fullerton?
The little placard does tell you about the boat. It will state make model and location of mfg., and maybe a couple other things. Hull ID should be in upper starboard corner of outer side of transom.
First 3 letters are Mfg., "SEC," or other depending on the year and manufacturer, 4th is model, 5th is length (a 0 for 20', a 3 for 23', etc.). 4 & 5 may be vice-versa? the rest are no., mo. the last 2 are the year of manufacture. Post a pic and we'll help you sort it out.
Cheers,
McG
Old 10-07-2016, 07:10 AM
many scalps many scalps is offline
Default splashwell
Originally Posted by Dogbomb View Post
I'll have to look into that! Would be cool to have a professionally made
unit instead of my own questionable design.
Please let us know how you make out with the splashwell. Nice craft.
Old 08-09-2016, 11:01 AM
Billybob Billybob is offline
Post some pics of that Donzi sweet 16 while you're at it.
Old 08-09-2016, 12:23 PM
Dogbomb Dogbomb is offline
Will do!
Old 08-12-2016, 01:28 PM
Capt Terry,
Rather than derailing Dogbomb's joy, Ill start a different thread or find a working link...
Regarding the flaring I used this tool, athough you'll need a longer bolt:
https://www.amazon.com/520290-1-Drai.../dp/B0082ANA0C
I believe Bushwacker flared his with an old deep well socket...
Cheers,
Gillie
Old 08-16-2016, 03:28 PM
bigeasy1 bigeasy1 is offline
Yeah,what a hackarama.
no boat should suffer that kind of indignity.
It's hard to believe someone could be such a hacker.When I was still thinking of keeping it I thought about going with a hydraulic steering system as suggested by Denny,as you wouldn't have to deal with that unweildly stiff steering cable.
Im Sitting in the rv now watching waves going from 3 to 5 and 6 to 9 feet.overnight. so keep the pics and thoughts coming so i dont get bored to death. The whole rv is shaking right now I feel like Doroty in the wiz of oz.UGH!!
All this,just for a boat ride
Old 08-16-2016, 04:08 PM
No fun! I hope the weather improves for you!
In the mean time, here's a glossy deck with a
new anchor roller. I'm making progress on your boat!
Old 08-16-2016, 05:42 PM
Default Transom Redone
Dogbomb- can't remember if your transom was redone. If not now the engine is removed is a good time to remove the aluminum around the engine cutout to take a look & reseal it.
Old 08-17-2016, 09:19 AM
Yes, the transom has been replaced, but I am going to remove and
reseal that trim anyway. They didn't exactly do a stellar job of
caulking and the aluminum needs a good polish anyway.
Good advice!
Old 08-19-2016, 01:13 PM
I try to make progress every day on the Seafari.
Today's progress was 3' more feet of deck wet sanded,
polished and waxed.
At this rate I'll be done by 2018!
