Old 01-08-2017, 08:21 PM
bgreene bgreene is offline
Default Sceptre with 1/0 questions
Better suited on this forum....
What's considered the overall " best " I/0 and outdrive from Sceptre /Tsunami based on:
1. Saltwater use
2. Performance........WOT around 45 mph, and good cruise speed fuel economy
3. Reliability
Old 01-08-2017, 11:53 PM
I'd vote for the Volvo DuoProp. My friend that ran the Moesly 21 Unohu for 27 years went through several MerCruisers. His last engine/outdrive was a 350Chev/275 hp Volvo. He said it was a 50 mph rig. As a structural engineer, he was very impressed with the design and construction of the Volvo compared to the MC.
Old 01-09-2017, 08:21 AM
I agree, the Volvo Penta duo-prop is a great I/O. My friend had a Scepter with a 502 big block coupled to a Volvo drive and it never gave us a minutes trouble. The duo-prop will also give you excellent traction in seas and low planning speeds as well.
Old 01-09-2017, 10:13 AM
What's the approx cost for that VOLVO set up ?
What's the typical installation cost ?
I generally see most with the 260 mercruiser.
Old 01-10-2017, 11:44 PM
BG - There's a sceptre on ebay with a volvo 290 drive (non duoprop). The boat looks like may need a new motor. I believe you can just swap the lowers and make that a duo prop. You could probably get a rebuilt lower duoprop and new 350 and be into the boat for short money.
Old 01-11-2017, 08:01 PM
350 CID / 260 hp Mercruiser bravo 1 outdrive...........Sceptre.........what's the average WOT speed ?
Old 01-11-2017, 11:33 PM
FLexpat FLexpat is offline
About 40mph but I didn't hang at WOT much
Old 01-13-2017, 11:06 PM
Dilligaf Dilligaf is offline
a 350 is a 350. i got a 2006 mercruiser 350 mpi with a alpha 1 outdrive. cruise 3400 rpms at 28 to 30 mph depending on conditions and whether curtains ar on or off. WOT is 40 mph. very fuel efficient.
Old 01-14-2017, 07:07 AM
Seems right on the target.
WOT speed a useful test measure of total performance and can show issues, big and small.
As a system check for engine, hull, prop etc.
Significant differential from " avg top speed for set up ".......would likely reveal somethings not as it should be.
