Old 03-25-2017, 01:01 PM
hermco hermco is offline
I`m a good mixer. Small batches are good for one ciggie.
Never knew there was colored mekp. So does this cure a darker color of red than
regular mek?
Old 03-27-2017, 08:29 AM
Originally Posted by pelican View Post
i'm confused
big difference between these 2 products...
If you don't "p" in it, it don't work. Drink lots of water before adding the p so the gel coat don't turn yellow....
Old 03-29-2017, 08:29 AM
By buddy has a chopper gun and was building Carolina skiff copies and was using clear mekp. Big mistake. One time he stopped up the gun or line to the mekp and sprayed half of a mold with out the mekp flowing and only half of the hull layup hardened. Big big mess. Then he went to red die mekp to ensure the mix was happening. Finally he sold the whole set up, and told me it was more trouble than it was worth. Clean up was a bit*$ and it was only good for spraying large molds (full hulls basically).
Me, I want to mix mine at the rate I want in batches. Throw away the mess hardly no clean up. If I for get to clean the roller...the bottle torch will fix that quickly.
If you did several full hull molds a week maybe but to do small jobs, I like to do it by hand.
I wonder if your buddy's setup was a pain because of the chopper gun? I wonder if just a mixing gun would be less of a problem.
I'm fairly certain the reason the red mekp was made is for these systems. I've used it before and it does help to let you know when you mixed enough. I really want to try one of these guns, but $1k is not an amount of money I want to experiment with. If it will make life easier and add value to my projects, I'm all for it, but so far I haven't gotten a warm fuzzy feeling!
