![]() Quote:
Opening out. Numerous reasons previously noted, and harder for hoodlums to open by kicking in. I stuck with the hinge on the right. I like the magnetic open position latch that Vezo described. Removable hinges is an interesting idea.
![]() Quote:
Hey Michael where did you get it? |
The only problem with using a magnet is that any metal with enough steel in it to be magnetic will rust! Maybe ok in a fresh water area, but not good in the salt! I've used a small nylon cabinet latch with a ball attached to door and a tubular catch screwed to deck at edge of step down. Has worked great for over 30 years!
Unfortunately it was broken during some mods by my mechanic, soon to be family, but knows where to get the replacement. I will have to get back to you.
Vezo. |
Good point on the magnet Denny, an adequate nylon ball catch is a good idea. I have original hook, but not the best for quick response if surfin Seafari alone. Rust and breakage = no es bueno. Maybe something like this?
http://www.tashcosystems.com.au/uplo...Ball_Catch.jpg
Very cool dammit .... Now you have me brain storming a door mod.....
Thanks, Guys.
Chuck: I would have to separate the stiles of the door in order to slide out the lower solid panel, so I think I will keep the lower part solid for now. I think the upper screen is enough ventilation for me - it stays cooler in Jersey anyway. |
Interesting. But then the first mate would not have the ability to close it when she uses the Loo.
