Old 12-12-2017, 07:20 PM
Wooley Wooley is offline
About to start glassing it
Old 01-11-2018, 11:45 PM
Rybones Rybones is offline
Originally Posted by ssscotty View Post
i had a similar issue when i had the 74 sceptre, i took one side of a motor ear muff hooked up to the hose and put it over each deck drain thru from the underside of the boat... and sure enough one side allowed water entry. i ended up re doing them with a heavier duty compression fitting. problem solved.
I had or have a similar if not the same problem on my port side. If I put a compression fit drain plug in from underneath the boat it takes on no water. Not the hijack the thread but could you give me a little more information regarding what you're talking about for a compression fitting, please? I'm looking for a better solution.
Old 04-26-2018, 10:53 AM
I’m finishing the coosa transom up .
