Old 04-12-2018, 07:47 PM
nate22 nate22 is offline
The bracket looks good. I can't wait to see it mounted on your boat. Good luck with the rebuild, and thanks for keeping us posted.
Old 04-12-2018, 10:35 PM
Lots of progress today. Have the new transom installed and all glassed in. 12” tabbed all the way. All that’s left is the addition of the big angle stringer I’m adding tomorrow. Hoping to have the entire transom finished and painted and the cap re-installed by the end of the weekend. Lots of work ahead still on the hull and deck to come. Hoping to be finished by the end of the month.
Old 04-13-2018, 10:03 PM
Finished the inside of the hull up today. Just need to Smooth out the hull and the bracket goes on.
Old 04-14-2018, 08:52 AM
Looking good, real good!!!
Old 05-23-2018, 12:57 PM
I saw your bracket install on Instagram, very nice, well done!! Looks extremely strong!
Oh yeah, good idea getting your son in on the work....."cheap labor"
Old 05-23-2018, 02:32 PM
Here are the finished pics. I am super excited to get the engine mounted next week.
Old 05-23-2018, 03:47 PM
fredbrad fredbrad is offline
It looks wonderful,I think it will work perfect on your seacraft, I have built something similar to the Stoner bracket and only what I need to be sure of the height from the keel to the motor top mount,on mine is 29"(set back is 27" and for a 25"motor shaft),could you please take the measure for me?. I'm hesitating if it would be necessary to cut it an inch and leave it at 28 ", so would the anticavitation plate around 3" above the bottom level of the boat
Old 05-23-2018, 04:02 PM
I mounted mine at 27” up from the bottom of the boat. It has a 28” setback.
Old 05-23-2018, 05:57 PM
ok, thank you very much for such a quick response, in my case I can only leave it at 28" without major complications, I will be waiting for your water tests and adjusting the engine height, I have a little more time in which I finish other things, thank you very much for everything
Old 05-30-2018, 04:35 PM
jctj123 jctj123 is offline
wats cost like on that wanna do least setback as possibly on my 18sf gunna add trolling motor batts in front hatch and move tank forward wen I get floor redone.
