Old 08-11-2019, 11:34 AM
lelandtampa lelandtampa is offline
I can remember reading in Florida sportsman when I was a kid a Vic Dunaway article about the Western Union splice. And how some connections he did as a young man were still intact. This was if course before the days of shrink tube. They just had liqiid electrical tape and untinned wire. Speaks to the tenacity of the joint if they held up with substandard coverings.
Old 08-12-2019, 08:11 AM
Ditto on Frizz...
Also use only tin coated copper wire over anything else...
Later
This is also a must. Glad you brought that up.
Originally Posted by JohnC View Post
Just an informational question - I have always stayed away from solder for marine connectors for fear of galvanic action (solder being a dissimilar metal).
Have you had any trouble with corrosion at the solder?
I think the key has to do with what you said about it being sealed. Tin coated wire seals the copper, The solder seals the wire and fills the air spare around the strands, the wire jacket also seal the wire and the heat shrink with glue seals the air from all under it. Keeps the salt air and moisture out of it. There could be some slight reactions between the dissimilar metals but it will be minor in comparison to salt air or moisture.
Old 08-17-2019, 10:07 AM
Agree completely on the tinned wire but I’m constantly amazed how many bilge pump‘s and other marine equipment comes with just standard copper wire you would think that they would know better of course cost is always the factor
Old 08-17-2019, 07:27 PM
Didn’t notice whether the wire was tinned but just replaced a still working Rule bilge pump which was perhaps 25+ years old. I also have a much newer backup.
Old 08-24-2019, 11:32 AM
WillyC WillyC is offline
IF you have some time, check out the link below. Gives a ton of excellent information.
https://marinehowto.com/marine-wire-termination/
