Old 02-09-2021, 08:57 AM
Kwaugh5p Kwaugh5p is offline
I know I sound like a broken record but...... Side Scuppers
I was thinking rear facing but side might be the ticket.
Old 02-11-2021, 05:31 PM
Originally Posted by take a potter View Post
Interesting only one access port on the platform. Does that mean it has no stringers? Or are they just not full height?
This is what it looks like inside as you can see the stringer is not completely to the top
Old 02-12-2021, 10:17 AM
take a potter take a potter is offline
Thanks.
Old 02-18-2021, 05:30 PM
More work has happened since the last post. They started ripping out the transom today.
Old 02-19-2021, 05:35 PM
A days worth of grinding
Old 03-12-2021, 09:49 AM
Well it has been a bit slow but finally some more progress the transom is sealed up and awaiting the new core
Old 03-15-2021, 02:02 PM
Starting to move along. 3 layers of glass tabbed in on the transom and rear vents filled in
Old 03-16-2021, 10:19 AM
Make sure you grind the edge on the outside of the vents and glass. If you don't they will separate at the edge on the outside and fracture thru the paint. Ask me how I know..... Both outside and inside require glassing.
Old 03-16-2021, 10:42 AM
They still have all the outside glass work to do on the vents. They made sure all the tabbing on the inside completely covered the vent hole. I do appreciate your comments Moose it is always better not to reinvente the wheel so to speak
Old 03-26-2021, 02:32 PM
Some more progress on the old girl. Transom has been recored with a 1 1/2 inch composite but before the composite was installed they layered the transom to 1/2 inch thick glass and finished it off with 4 more layers. The scupper drains are filled in as well as the old live well pick ups. The vent area was ground and glasses from the outside as well. Next steps are to build the stringers back to the transom and build the pocket for the through hull transducer than the floor.
