Old 03-16-2021, 05:26 PM
abl1111 abl1111 is offline
Default For sale - 1975 23' tsunami
1975 - 23' Tsunami
Complete Resto in 2003/2004.
RESTORATION:
- Complete removal of all excluding windshield frame, Kiekhaffer steering helm/cable, Marinium cleats.
- New Transom, Floor-hatches re-cored. Anything marginal - replaced.
- All new wiring, and electrical components
- New windshield glass, gaskets, upgraded windshield hardware
- Fuel Tank Inspected, repaired, epoxy sealed
- Converted twin V4 i/o’s to single V8, new motor beds, added bulkhead – professional grade fiberglass, engine, rigging etc. Customized the way I wanted it. One of a kind.
POWER:
- Mercruiser (2003) 5.7L MAG MPI HORIZON 350/ 300HP – Freshwater Cooled, Closed System – currently with 1050 hours – in excellent working and cosmetic condition. Thru-Hull Raw Water intake (South Bay strainer), New Heat Exchanger, R/R Complete Transom Mount, Steering Ring, Gimbal, Oil Pan, Commercial (steel) Coupler, Sea Water Pump (w/ spare), Starter
- Mercruiser Bravo 3 Drive (2003) in excellent working and cosmetic condition. New upper U joint shaft (2017/2018)
- Mercruiser Flagship Gauges, Blue Sea/ Carlin Switches
HULL:
- Original Gelcoat in great condition.
- Hardtop with StrataGlass (2017) & Rocket Launchers, Dual Flood Lights.
- Deck Lights (4) mounted under gunnel
- Simpson Lawrence 600 Windlass in perfect working order with robust deck support (working spare windlass unit included) and Windline CAR4 Anchor Roller
- Full Teak Swim Platform with Windline (3) step telescopic ladder,
- Bennett Trim tabs with 12”x12” tabs (epoxy sealed), Lovered vent frames powder coated
- Hull to deck joint bolted as opposed to OEM screwed
Peripherals:
- Custom foldable cabin ladder
- Electronics – 2017 Garmin model 74CV - 7” Display with CHIRP transducer
- (2) New Dekka Batteries (2020), New Fuel Sending Unit (2017)
- Dual Bilge pumps; (1) Auto, Rule 1100. (1) Manual Jabsco Water Puppy
- Live Well pump ShurFlo 800GPH, and Shurflo Par4 Washdown pump,
- Attwood Engine Blower
- Ongaro Hard-Top Mounted Horn
- Brand New SeaCraft Decals (2020)
- New Perko Navigation Lights (2020)
- New Engine Sound Insulation (2019)
- Standard Horizon VHF
Maintenance: Complete, comprehensive maintenance log including Parts, Work completed, dates/ engine hours - from restoration to-date. Annual Antifouling – Hull: Petit SR60, Drive: Primocon/Trilux.
Complete Survey post resto/ pre-launch available (2004)
- Owners Manuals for all components
- OEM Shop Manuals for Engine and Drive (PDF File)
Trailer – A Gift – mid 1980’s Rocket Trailer – original registration available
I am incredibly torn about this move. I have owned and used her seasonally since 2004. She is in great shape and well maintained. If you’re looking for a Tsunami, also known as a Sceptre, this is a clean example. This description and pix (to follow ) tell the story. If interested - get in touch via PM. If you're on this site - you know about these classic hulls. The ride, center of gravity with the i/o and Bravo 3 drive - is simply amazing in every sea condition. If some say an outboard in this hull type rides and performs better - I don't believe it. Search my username and you'll learn as much as you need to know about this boat.
$19,500
Transaction ID: 1E950601CD161344T
