Old 03-30-2021, 07:06 PM
striper56 striper56 is offline
Thanks everyone for the information. It looks like the 2/0 wire is the way to go. One last thought could I run the 2/0 to a block on the transom then switch it to a #1 or 1/0? I think the 2/0 will be a bitch to get through the harness.
I found a guy with the same motor who is willing to do the amp test this weekend. I will report back the results.
Thanks
Old 03-30-2021, 10:17 PM
erebus erebus is offline
You can run the 2/0 to a block on the transom and then switch over to the factory outboard battery cables. Very standard install.
I used one of these in the transom with a 3/8 stud:
https://www.bluesea.com/products/cat...Dual_PowerPost
I looked on my Sceptre today and I guess I did end up using 1/0 from the batteries to the transom. Oh well, I thought I had used smaller stuff.
Ran the OEM Evinrude cables through the rigging tube and hooked them up to the power posts.
Engine has a dedicated battery. Used an Automatic Charging Relay to charge the house battery. Batteries are under the floor by the helm.
Zachary
Old 03-31-2021, 07:32 AM
Thanks
You need to calculate the load. What you're suggesting will negate the larger wiring on the longest run.
Old 04-06-2021, 01:06 PM
Surfnski Surfnski is offline
I wouldn't try running 2/0 through the rigging tube, splice lugs at the transom is the way to go. Another thing to consider is shortening the factory leads if you have a large amount of excess coiled up at the transom.
Old 04-06-2021, 04:05 PM
Actually it will not. As long as the smaller tap cable is on the load side you will negate the majority of the line loss in the 2/0 running from the front to the connection point at the transom. I also agree that ridding any excess coiled wire from the motor feed is best. Wire coils are chokes (resistors) and add to the load.
