Closed Thread
  #201
Old 03-27-2007, 09:53 AM
Bryan A. Bryan A. is offline
Default Re: Here We Go Again
Nice job, as always.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
  #202
Old 03-27-2007, 12:10 PM
RingLeader RingLeader is offline
If the California tree huggers just knew what you were doing over there...
Looking good! You are making some good progress.
  #203
Old 03-27-2007, 05:39 PM
Ha Strick
You got almost 8,000 hits on this thread so far. That got to be a new Record, I don’t think it will be broken for a very long time. Matter of fact I think we should give a award for that. How about calling it the BOAT PORN HEAD PIMP OF THE YEAR award.
FellowShip
My motto: Just for the Grins
  #204
Old 03-28-2007, 12:27 AM
LMFAO Thanks Fellowship I'm honored. I'll get busy on my acceptance speach.
I poped the hatch out of the mold tonight. Here area few pics.
It's fits perfect and is solid. This is the way I'm going to make hatches from now on. BTW if you are wondering why I did not prime it with duratec like I did the floor it's because I was in a hurry and forgot to.
I left it sit slightly high on purpose. Now all I have to do is grind about 1/4" off the hatch lip so it sits flush with the deck and then I'll prime it.
  #205
Old 03-28-2007, 03:53 PM
GradySailfish GradySailfish is offline
Strick, its great you just did that project because I have a hatch I need to build as well. The tank coffin lid on mine was warped and cracked....basically unsalvagable, so I had the idea of making my own.
Once my Grady is back in the water I'll start work on the SC again and thats one of the first projects I plan to tackle. My plan was basically the same as yours, but I was going to put some gelcoat in the mold before hand, but since I'll be painting the boat anyway, it doesn't really matter if I do that.
Can you explain how you got those edges so perfect? I know you used clay but can you be more specific? I saw somebody use bondo to create the rounded lip....do you think thats a good idea? Did you use MDF to lay up the tank lip?
Thanks in advance...your project is looking great.
BTW Otterlycool, this is Alex from Capt. Dan's Capt license class. Remember me? I'm rebuilding a 20 SC right now. Getting the topcap off was no problem...I undid all the screws holding the cap and hull together, cut the adhesive between the hull and cap, and after some persuasion utilizing crow bars she popped right off.
http://i37.photobucket.com/albums/e5...h/IM000954.jpg
That pic is kinda unclear but shows the cap pulled foward. I later got help from a couple guys and we lifted the cap off the boat, placed it on the ground and I recored the cap and put it back on......which required crow bars and jumping on the cap!
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
  #206
Old 03-28-2007, 04:23 PM
Rich Rich is offline
Strick,
why use the small plywood squares for coring? Why not just use one sheet? Will the small squares create a stiffer panel?
Cape Marine Supply
  #207
Old 03-28-2007, 07:04 PM
Grady- I used some wax based modeling clay called Supersculpy. If you go back a page or two you will see a pic of it. I rolled it into long thin pieces and then pressed the pieces very firmly into the bottom edge around the preimeter of the mold. Then I took a plastic spoon and with very hard pressure ran the spoon several times over the clay keeping the same angle. For lay up I cut 4 small 1 inch squares of cloth and stuck a piece into each corner then I ran some 2" cloth tape around the edge of the mold. I should have taken a pic but did not.
Rich--> when I re did my hatches on my 23 they were all cored with the plywood squares and I thought that was kinda a weird way to core something. With the squares you don't have to worry about a single piece of wood being slightly warped. You get better surface contact with the squares and I do think it is stiffer because of the cabosil between the squares. Also you use less wood and you can cut up your scrap. There is only 1 layer of 1708 on the bottom of this hatch and I can jump up and down with no flex at all in the hatch.
  #208
Old 03-28-2007, 07:24 PM
Ed Ed is offline
Rich-
Most production boat builders who build boats with wood cores, use the squares instead of single sheet. As Strick alluded to, the reason is that each little square will adhere better...much more so than one large piece. Another advantage is that if you fully encapsulate each piece in resin, you are less likely to have water creep through the entire coring causing it to rot as is commonly the case with a single piece of wood coring.
Finally, the little pieces...mean less wood is thrown out as scrap....which can add up to a lot if you are building a couple of thousand boats a year.
-Ed-
  #209
Old 03-28-2007, 07:40 PM
Don't forget it's easy to store squares in a cardboard box and a hell of a lot easier to move a box of squares than a 4x8 sheet of plywood. I think the resin/cabosil grid prevents delamination and increases stiffness.
  #210
Old 03-28-2007, 08:08 PM
hermco hermco is offline
One of my first jobs in the marine industry at Sea Vee Boats Miami FL in the early 80s was reducing 4' x 8' plywood into 5" squares to feed the lamination dept. I was glad when they switched to Divinycell foam core!
Closed Thread
