#231
Re: I Need A Shrink !
Progress has been Slow but sure over the last several weeks. A milestone was getting both fuel tanks finally
installed. I needed to make some modifications to the the bulk head where the fuel lines ran through in order to keep a gradual slope dowanward to the tanks. Installing the sending units. Some goodies that the welder left inside the tanks. Tanks in place. Eack tank has an antisiphon valve. The tanks are bonded to their respective fuel fills, bonded to each other and bonded to the engine block. Valve for switching tanks Recreating the cabinets in the 25 seafari. Note the messy shop! There are two cabinets. The one on the starboard side simply has a storage area underneath while the one on the port side has a lift up door that houses a porto potti. I still have some finish trim to install here and there on the cabinets. I've been trying to re use as much of the original hardware as I can on this boat. It's all good stuff that just needs a little polishing. The marion cleats My seats finally arrived. Fancy gucci steering wheel. It's made in Italy and was on sale for $64.00 I went to a local wrecking yard and purchased an old Morse control. I like the look, feel and simplicity of it. Gaffrig/Livorsi gauges. I bought these off a buddy of mine 5 years ago. I knew they would come in handy some day. I spent most of the day today cleaning my messy shop. Time to get back to work strick
"I always wanted to piss in the Rhine" (General George Patton upon entering Germany) |
#232
Impressive!!!!! As always.
The boat is a work of art. Will you use it or put it under a glass dome and admire it? |
#233
BEAUTIFUL work Strick! That's gonna be a GREAT fishing AND cruising rig! I see you have one spare hole in the instrument panel - might want to consider putting a vacuum gage there. It can tell you a lot about engine performance!
Denny
#234
Denny- The extra hole is for the other fuel gauge. I will probably install a vacuum gauge at some point if I like the way the IO handles and services. If it gives me trouble then off it goes as an artifical reef and a bracket with twins will take it's place. I was going to try and find that thred were you were discussing vacuum with Conner. strick
#235
wher is the gas gauge
#236
Strick,
You could use a 3-position switch on the senders and then read both tanks with the same gage . . . would save drilling a hole for another gage! Here's a link to the post on the vacuum gauge.
#237
Beautiful Doc,
When you first mentioned painting her grey, I had impure thoughts. It is nothing close to what I had pictured in my mind. Very tasteful and subtle. Somehow it makes her seem as if she`s in the water. I forgot to mention that I think you will have trouble changing the handles on the ball valves. Can you rotate them for better access or is there no room? Who made the all bronze seacock? I`m just finishing up a plug for a mold. It`s for another Flintstone idea of mine. Small part for fishing. Had I not gotten the sickness, I would not have had the trail of bread crumbs for inspiration. Thanks a bunch for the time you spent documenting your travails. Cheers, Sandy. Sandy 3 Mutton 0 Yum! Cool and cloudy too. |
#238
Strick, what do you keep in the Browning safe, anything interesting??
Boatless again! |
#239
Man I hate how they leave debris in tanks! This cost me big time on mine. Good move taking the time to look @ it 1st. What will the boat be named? That transom needs a name
__________________________________________________ ________________ 1974 23SF |
#240
John- Lisa said to name it "Widow Maker" but for now she will remain nameless. Just ask Bigshrimpin about aluminun shavings in gas tanks. Hopfully they are good to go now. strick
