![]() Quote:
Motor is 421# Bracket set back is 24.5" strick |
Yeah strick,
You were right - the Sceptre 20 grows on ya a bit ![]() Looks great! Tell us about the change in performance when you raise the zuke. Balance looks really good. WTG, again! ![]()
Not easy to make transoms and warped planes look straight and fair with dark colors.
What? GFS |
Fred the seats are from Overtons:
http://www.overtons.com/modperl/prod...A&merchID=4006 They are the perfect size for this boat. I set the helm seat back a little further then the other side. For me it is comfortable to sit or stand the way I have it set up. I have to lean down a little when standing ( I'm 5'10" ) so if you are taller then you may want to get a tilt steering wheel. I have a suicide knob on the wheel but can still clear my legs but it it close. I had the same worries as you but it worked out OK for me. The little rubber stops came from Orchard supply The one on the windshield was a solid rubber stop and I drilled out the center so a ss wood screw could attach it to the window frame. The one on the center hatch has a brass insert with threds and I have it bolted to the center hatch with a ss machine screw. Calked the fuel tank hatch and the perimeter of the live well this evening. Hope to have blood on the deck soon. Sandy thanks again for the compliments ![]() strick |
You probably have some idea of the emotional gamut i`m running.
pins n needles. |
Thanks Lloyd and Beaver!
OK so today I finally had time to take the boat out for another test run. I always like to run the boat on the muffs at home for a few minutes just to make sure all systems are go before I trailer it down to the ramp. She was idling fine for a while and then the engine died out. Re started it and it died out once again. Now I'm pissed because I really want to get down to the water and Lisa was looking forward to taking her first ride in this boat. I started pulling things apart and noticed that the fuel line had some clear silicone gunk inside of it. I'm thinking how in the heck could anything have got past the fuel filter and how did anything get in there in the first place. So I took the brand new fuel line off and got to really looking at it and that's when I found that the the inside of the fuel line was delaminating. There is a plastic like material that lines the inner part of the fuel line and it was coming apart and restricting flow. Note the pictures below. This is Sierra USCG rated fuel line not more then 3 weeks old. I had originally been looking for the regular old black 3/8 line (teleflex) but WM was out of that so I ended up with this crap. DON'T BUY SIERRA FUEL LINE. So I spent most of the day today tearing out all the calking around the fuel and live well hatches so I could remove them to get to the fuel lines and replace them. Finally by this evening Lisa and I were ready to do another test run. There is less spray now that the engine is up 2 more holes but there is minimal gain in RPM. WOT is still at about 5500 RPM and doing 35 knots. I think I need another prop and since I am not really into propnology I will look to the board for help on this one. strick
"I always wanted to piss in the Rhine" (General George Patton upon entering Germany) |
Amen to that. Although I don't have firsthand experience, I had always been told to stay away from their stuff particularly when in it comes to the fuel system. Too much to worry about there to save a few bucks over OEM or better quality stuff. This is one area where it definitely makes sense to spend the coin on the good stuff.
Strick, I wonder if those were Non E-10 rated hoses that were mislabeled as E-10 rated?! If the boat sat for a couple weeks with E-10 gas in the lines, that might be long enough to cause that problem! I'd be inclined to complain to the place I bought them from, as a recall is probably warranted!
My old lines WERE E-10 rated Sierra hose installed in 2006, and never caused any problems, but just to be safe, I replaced everything between tank and engine a couple of years ago with genuine BRP stuff including the primer bulb, because I'd heard of guys blowing powerheads due to lean operation/fuel starvation from restrictions in the line. Now I'm REALLY glad that I replaced them! That can kill any motor, 2 or 4 stroke, but it's especially bad if you're running a pre-mix 2-stroke because you starve the motor for oil as well as gas! There is a good message here: ANY TIME your motor suddenly loses power, check it out and try pumping the primer bulb before you just give it more throttle! If it speeds up after pumping the bulb, you may have an air leak in the suction side of the system, a weak lift or fuel pump or some sort of restriction, especially if it slows down again after you quit pumping the bulb! If it doesn't clear up and the bulb stays flat, there is a restriction upstream of the bulb. If bulb is hard there is a restriction between bulb and motor. Running a motor hard when it's starving for fuel can ruin your day (as well as the motor!) Because of that problem, BRP developed special test equipment that a good dealer will use to check out a boat's fuel supply system on all new motor installations before they even run it. This test consists of installing clear tubing with a very sensitive vacuum gage tee'd into it between the boat's fuel line and the motor. They disconnect the fuel line from the HP pump outlet and install another long hose from the pump discharge back into the fuel tank to recirculate fuel. They plug in the laptop, turn the key on (but don't start motor), and then use the laptop to run the HP pump at max flow and look for air leak bubbles in the clear hose while they monitor the vacuum. It must be a VERY high flow rate, because my I-Command gage, which gets fuel flow from the EMM and remembers fuel used, said I had used 14 gallons during the test which only ran for a couple of minutes! The maximum allowable restriction on the E-Tec's during that test is 0.5"Hg vacuum. I eliminated a couple of 90 degree elbows in my system to get the restriction down to 0.35 -0.4" range. Denny
![]() Quote:
Sorry to hear about the hose. That sucks. Hopefully no goop got to the injectors. Surprised you saw no performance change with the 2 holes. What prop are you running now? What were you running on your other 20? 140 Zukes on both, right? With its 2.59 gear ratio, that motor should be able to swing a lot of prop but the extra 100 lbs 2' back might mean you have to reduce your pitch and get more surface area; and reduce cupping and rake to raise the rear end some. Don't know what you have, so I'm speculating here. I think Denny is running a 15x15 ELE4 from PT Props. Logic suggests a strong stern-lifter is in order. I think the zuke is a smaller diameter gear case but maybe something similar in 14x17 would get you up to that desired 6200 rpm WOT. 35 kts ain't bad, though. Maybe get to 37 or 38 knots with another 5 or 600 rpm, IDK... I thought someone else on here had a bracket mounted zuke 140 on their 20'. Maybe they'll chime in... Good luck Chuck, Gillie
there's no such thing as normal anymore... Last edited by McGillicuddy; 02-19-2013 at 02:39 PM. |
Strick,
Here's a couple of pics of a Tsunami I was eyeballing a while back. May give you some ideas for your 23. Personally, I really like the bench seat in the rear. John |
