  #231
Old 03-03-2015, 08:19 PM
update alright the boat has been moved to the shop and should get started in the following days.
pics to follow
36' Yellowfin
1972 20' seacraft 140 suzuki
Old 03-03-2015, 09:34 PM
Waiting in t shirts here.
Old 03-29-2015, 10:31 AM
Alright i am in the sunshine state getting some much needed vacation after my winter of outside side work.
The boat is being worked and i will post pics when i get home . As my feeling were correct randy is doing an amazing job of finishing the boat off for me and i cant wait to see it painted.
36' Yellowfin
Old 04-03-2015, 11:41 PM
here we go
the first orderof business was for randy to fix a hasty decision I made to squirt potter putty up under the gunnel between the cap and hull sides. the pic is of the 2 lbs of putty he ground out. after it was all cleaned he glassed the cap to the gunnel all the way around.
he ground down the outside of the cap where 42 years of rub rails and what ever else was mounted an put some glass on there also. He got more glass on the rear boxes where I ran out of time do to stuff before I brought it to him. he shaped and grounded and put the 1708 down in a certain way so any of the inside angles were not cut pieces. Its amazing home much I learned in his shop in the couple hours I was there.
the fairing was applied to the inside hull liner and was starting to get faired.
36' Yellowfin
Old 04-03-2015, 11:45 PM
he dadoed out the foam around any hatches and putty packed around them to make them solid
also a pic of the fitted scupper.
and the last pic is when We were at the bar drinking.....
36' Yellowfin
Old 04-03-2015, 11:51 PM
I am back now but the some pics have been coming daily
randy suggested that he put a layer of mat over the entire gunnel cap to prevent any spidering from showing through the paint in a couple years. I agreed and he did it.
progress being made they got the high build primer shot to the boat and now the sanding starts
36' Yellowfin
Old 04-04-2015, 08:41 AM
You won't be sorry...I did that on the 21 and no spiders have shown up (and there were a ton of them b4 I started).
The only place I did not do it was in the V-bunk since that was going to be cushioned...and guess what? Yep some small hair lines are showing up.
However fairing all that stuff out was a real PIA
Old 04-13-2015, 09:20 PM
alright I finally got some time to post some more pics of the progress.
here is a shot of the braces put under the gunnel
the next couple are of randy doing what he does best, making boats ssssssmmmmooooth
Randy's son works for him and is learning the ropes of 35 years of elite fiberglass work.
36' Yellowfin
Old 04-13-2015, 09:26 PM
Randy laid 2 extra layers of 1708 on the inside to beef up the engine shround, couple layers of mat on the outside and started fairing and shaping. The fit is amazing, like it grew there
36' Yellowfin
Old 04-13-2015, 09:30 PM
the insides have been faired out and sanded flat and smooth, the cap has been faired and sanded out. the next step is to put the radius back in the boxes and the gunnel cap. the high build primer will take care of the rest of the fine fairing.
36' Yellowfin
