  #241
Old 06-17-2013, 09:19 AM
20’ SeaCraft SF with bracket
Performance Data
6/16/13
Calm seas.
40 Gals fuel, one person, med load.
14 ¼ X 17” 3b Yamaha SDS Reliance Prop.
RPM GPH MPG Spd Knts.
1000 .7 8.3 5.
1500 1.3 6.8 8.
2000 2.2 4.8 9
2500 3.3 3.8 11
3000 4.3 4.7 18
3500 4.9 5.1 22
4000 7.2 4.3 27
4500 9 3.9 30
5000 13 3.1 35
5500 16.5 2.4 39
6000 19.5 2.5 44
I still need to do some playing with engine and prop. Want to get a little more speed out of her. :-)
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 06-17-2013, 10:38 AM
drtyTshrt drtyTshrt is offline
As mentioned before. That 5k RPM slot looks good.
I bet you could go to a 19pitch and stay pretty close with your numbers.
The trouble with trouble is it starts out as fun. (Mark Twain)
1989 20ft C/C SeaCraft/Tracker 1989 200 Merc BlackMax.
Old 06-17-2013, 12:25 PM
I'm going to raise the engine up a notch.
Try a four blade.
And will try a 19".
I like what you are saying. ;-)
1974 40' Eagle
www.parkeryacht.com
Old 06-17-2013, 01:36 PM
hermco hermco is offline
Nice clean job there young man.
Old 06-17-2013, 05:01 PM
I agree! Beautiful work!
Old 06-17-2013, 10:34 PM
the four blade should help lift the stern at lower speeds also !! maybe even try out a 5 blade.... ;-) get speed lift and load carrying..
RUSTY PARKER
Old 06-18-2013, 02:50 PM
YeA 20sF YeA 20sF is offline
Perfection.... Nuff said
Old 06-19-2013, 05:52 AM
Originally Posted by Calibogue View Post
Your lenco actuators mounted through the bracket!
I will need to do the same for them to fit and get the bracket height correct.
How much rise did you use per inch of setback?
For every 12" of setback, I raised the engine an 1", or should have.
I am happy with the bracket height, it is down low enough that I get a good portion of the flotation values, I can still mount lights, thru hulls, etc, thru the main hull and it is a good height for boarding.
But I feel the engine could go higher, so I will raise it a notch.
How is your project progressing?
I thank everyone for their kind comments.
It appears as if the wind Gods may have changed their minds, the first forecast for this w/e was ESE 15-20knts, little too sporty for my taste in this boat. Now that has been revised to 11-14knts, if that is the case, I'm ouuta here!!
Final touches going on, TUUCI Top, etc.
Last is the cooler, spear, rods, fins and TM/LLL II. :-)
1974 40' Eagle
www.parkeryacht.com
Old 06-19-2013, 06:42 AM
Calibogue Calibogue is offline
By next Friday I will be ready to hang the engine!
Thanks for the info....I have been dreaming of bracket heights.
Old 06-19-2013, 06:55 AM
From everything I have read and what I have been told this is a good starting point. Most everyone has had to raise their motor up from here and never down. So make sure you leave your adjustment so you can go higher from this point so that you can fine tune it in. I am also starting at this mark and setting the motor so all my adjustment holes will allow me to go up higher if needed.
