  #251
Old 09-11-2016, 09:01 PM
martin martin is offline
Default Thru hull scuppers being installed
Well after some measuring and finding the correct hole saw bit I decided to drill some through hull scuppers drains for the deck.. in between the never ending fairing..
Old 09-11-2016, 09:39 PM
Default Scupper install
scupper install
Old 09-11-2016, 09:46 PM
1. Pic I measured and drilled the hole
2. Rabitt the hole out and then put a wet coat of epoxy on..
3. Then back buttered the rest of the epoxy with cabosil thicken epoxy
4. I taped the thu hull up and waxed the snot out of her.
5. Installed it about 2/3 in let set up
6. Then pull out very carefully...
7. Inside the deck liner I modified the floor drains to mount vertically measured in from side 12" and drilled a hole . I am amazed at the thickness of glass on that liner.. about 1/2" thick
Old 09-11-2016, 09:47 PM
Oh yea in-between all this more fairing going on
Old 09-11-2016, 09:48 PM
Default Port side rub rail
Fairing , fairing
Old 09-11-2016, 09:51 PM
[QUOTE=martin;246574]Fairing , fairing[/QUO
So close but so far away
Old 09-12-2016, 11:25 PM
Default Transom core
This is what it looks like.. .3/8" glass inside then two 3/4" ply. Then 1/4 foam then 3/8" glass skin.. this is all new glass as I cored it from the outside of
Old 10-22-2016, 10:09 PM
Default Started installing the trim tabs
Had some tabs laying around so I thought I better drill and in stall them... I want to have everything drilled and cut first then paint and reinstall the hardware..
Old 10-22-2016, 10:12 PM
First drilled holes oversize then chamfered the holes ,then I mixed a epoxy and brushed it in the holes ,then last I mixed some thickened and squirted it in the hole from the back to the front with them handy syringes
Old 11-27-2016, 09:19 PM
Default Still working on rub rail
About got the rubrqil done. I ordered the stainless 316L hollow back 3/4" from marine industries Inc.. great people and very friendly. Ordered3 -20' sticks... Very inexpensive with freight shipping...I should have the rubrqil done by the time it arrives...I started on the floor ,.. bought a 4*24 belt sander and commenced to know don the high spots and sand the whole deck down. To accommodate the teak...
