Old 04-13-2002, 11:37 AM
Scott Scott is offline
Default Re: Potter Outboard Bracket
DH
Thanks again for your response...Those pictures.. they were great esp. of removal and finished work of the 23....really shows you what you get with this system....I LIKE IT A LOT.... [img]images/icons/smile.gif[/img]
Did you save the in deck live well in that 23???
Sure does look like you did!!!
Again Great work !!!
I'll be in touch
Scott
Old 04-13-2002, 02:34 PM
hermco hermco is offline
Steve,
The kicker on the 23' is a 15hp 4 stroke merc.I had an aluminum mount made to fit it to the dive platform of the bracket.Worked out quite well.
Old 04-13-2002, 02:40 PM
Scott,
Yes the livewell is still usable after the mods.The owner uses the boat primarily for diving so the system really opened up the cockpit giving him a lot more area to load tanks and a dive door.By the way he got the ladder installed and it seems to work well for him.
Old 04-13-2002, 02:46 PM
Snookerd,
Adding the 5" is not a big deal.I have to do it on the Makos because they are cut for 20" motors.You add a piece of 2x6 cut to 5" and glass.In the end it is not a structural or load bearing area.And you don't have to finish out the outside because the bulkhead panel covers it.
Old 04-14-2002, 01:57 AM
DH-
Thanks for the transom height requirement info. I think I would have to go up 5". Tell Mr. Potter Thank you from me for his talented work.
Old 04-23-2002, 01:32 AM
When I spoke with Bill Potter he warned me of this...... Sounds like an inspection plate leaking
At least I hope so for this guy....
DH ...I would guess you've never had this problem with Potter's bracket?? and if it is and O-ring to a deck plate .. well thats his own fault
http://www.thehulltruth.com/ubb/Foru...ML/000631.html
