Old 07-09-2003, 12:38 AM
BARNABY55 BARNABY55 is offline
Default Re: gel coated the hull today.
Hey, If you are truly stressed out and need to do something else for a while...I'll let you have my 18 to re Gel.
Ted
Old 07-09-2003, 01:19 AM
LITTLEBISHOP LITTLEBISHOP is offline
Hi Ebeach, Thanks....When you added color, which manufacturer's product did you use. I'm wondering if allgrip is mixed with gelcoat? or are gelcoat "colors" made by another company? And who makes the gelcoat product? Thanks Marc
Old 07-11-2003, 10:01 AM
RingLeader RingLeader is offline
West System claims that their epoxy is an excellent base for polyester gelcoat. The kicker is that they are talking about after a full cure is achieved, the amine blush has been removed, and the surface has been roughed up. It is strictly a mechanical bond. Which is all you get in a repair instance if you were using polyester or Vinylester resins (unless you can make your repair layup smooth and even with no resin runs or sharp edges).
Anyway, I have been making repairs with West System on the Mako for 3 years now. All of them have been gelcoated and no problems thus far. The first project I did was to grind out all the gouges from the stem (about a 5ft long section up each side about 6". I laid 2 layers of 1.5oz mat then a layer of 6oz cloth to top it off. Sanded and filled, sanded and filled, and sanded and filled. Then sprayed gelcoat. It came out really nice, and hasn't shown any signs of blisters, cracking, or chipping. Its all in the surface prep though.
You cannot spray a mold with gelcoat then lay up the glass with epoxy though, they are incompatible and will not chemically bond to each other or cure correctly for that matter.
I did some repairs for my father in law, and he had already filled some spots with an off the wall brand epoxy filler. The filler was cured and sanded, and I put gel coat over it... The gel coat would not even kick off over that stuff. No cure what so ever! I scraped it all off and tried again. No luck! So some epoxies will not even allow gel coat to cure after they have cured! So West Ststem is correct and their stuff is compatible after cured and prepared.
Heres a new idea of mine. I have heard that vinyleseter is compatible with epoxy as well as polyester. So use vinylester filler over the epoxy or even hot coat with vinylester resin before you apply gel coat. That way the vinylester will be the middle man which both parties will adhere to. Haven't tried it yet, but I am planning to. Just a thought from a fool who hasn't come over the the simple world of painting yet.
Old 07-11-2003, 10:42 AM
EBEACH EBEACH is offline
RingLeader, Try this out.
Epoxy tiecoat
Old 07-11-2003, 11:14 AM
Trayder Trayder is offline
Velvet Jones
There is a sailboat company, C&C Yachts , That sprays gelcoat in a mold and utilizes epoxy for the layup.
I do not know if they use polyester gel-coat but I have a feeling it is a Vinylester Gel-Coat.??
Old 07-11-2003, 02:39 PM
Boy the rules keep changing when I started my boat no one recommended re gel coating the entire boat gel coat was for either new construction or just for smaller repair jobs. Now we are talking re doing the entire boat using epoxy then putting gel coat over it. Well looks like “if I had to do it all over again” I have another thing I would do differently that how I did mine.
Fellow-Ship
[img]images/icons/rolleyes.gif[/img]
Old 07-11-2003, 03:02 PM
Well this Gel Coat over Epoxy question got me bugged enough that I posted the question to the West Epoxy Question / Answer board I will let you know what they have to say about the subject when they respond to me.
Fellow-Ship [img]images/icons/cool.gif[/img]
