Old 01-12-2007, 01:44 PM
Kmodi9 Kmodi9 is offline
Default Re: 1976 23 Inboard
i too am looking to have a white bilge perhaps, any reccomendations on paint?
Shurwin Williams Tile Clad HS.
The price is right and a ideal product to be immersed in water all the time.
No primer needed.
is it a two part? why this over a marine paint? Thanks!
Old 01-12-2007, 04:10 PM
I replaced the entire deck, re cored the cap, did the transom, re did the gas tank deck, new gas tank, re did the CC, and on, and on, and on, all new everything plus as this picture shows removed the paint on the out side of the hull back to the original gel coat and then painted. I really learned how to drink MASS QUANTITIES OF BEER and burned out 2 electrical orbital sanders in the process. If you go to Gallery and click on Fellowship there got to be 30 + pictures of my over one year 150 day project.
FellowShip
My motto: Just for the Grins
Old 01-13-2007, 12:49 PM
Bryan A. Bryan A. is offline
Its a two part epoxy paint. Aparently designed to paint the inside of water tanks and stuff. I wouln't use it on the exterior because of the UV. I'll let Warthog chime in with the details (he did the research). Thanks Warthog.
Why over marine? Because the marine designation just means double the price. It is available at any Sherwin Williams store. You get alot of paint for the money.
I'm not one to just take someones word just because but when a product is right as far as cost and performance it works. This is not my boat it is Warthogs X-shark with the Tileclad HS applied. Good product and cost effective. I'll get off my soapbox now.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 01-17-2007, 11:12 PM
GetReel GetReel is offline
I gutted and re-did a 1975 IB. The PSS dripless shaft log is great. I suggest you pull everything you can and get a moisture meter on everything and make sure its not soaked. As you have no doubt picked a unique boat, beware the advice from the outboard skiff riders... ...they dont understand this boat.
Old 01-18-2007, 12:01 AM
what is a moisture meter? what do you think are reasonable moisture readings? Tell me about yours Jeff H. got any specs?pics?
I have a question for all inboard guys out there.......what are the engine mounts made off, whats underneith that glass? are yours bolted in with heavy threaded lag bolts?
Old 01-18-2007, 05:24 PM
I sent you a PM. I'm bolted in, most of the boat is plywood covered in glass. Try to get to everything laid out before you start putting the parts back in her, not much room to work with if you have to go back in...measure twice, cut once.
Old 01-20-2007, 06:48 PM
dmese dmese is offline
Good stuff. I have one of these projects myself located in Chatham. The deck is out. Motor picked out. and grinding in progress. If you need any motor/trans parts let me know.
Old 01-20-2007, 07:41 PM
dsharp dsharp is offline
If you can find industrial imron it covers and sticks well. It has about 2x the solids as the auto/marine imron. Plus it's brushable. It's a 2-part poly. With that prop size are you running a 1.5 to 1 borg-warner? If you are running a bw be conservative on the cam. You need to get a smooth idle at about 750 rpm. I tried to use an rv cam on a pair of 454 Crusaders on a customers boat and we couldn't get it to idle smoothly and it sounded like @$#% when you put it in gear. It may not be too bad in a lighter boat. You may just want to take out a little pitch to get the rpm up to about 4200 at wot. Just a thought.
Old 01-21-2007, 02:02 AM
thanks for the comments and offer! i a knee deep in work right now, and tryin to make some headway. Whats the deal with your project? what are the specs? what motor did u pull?
Old 01-21-2007, 02:07 AM
i am running a 17 by 17 with a slight cup and it seems to work well. I get some noise around 1800 nut othe than that it seems like a good fit. It bites well, and isnt so bad on wot. I hope i dont need anothe prop once the explosion box i rebuilt, but we will see. as evrything thing in life......this is a work in progress.
Where can i get get the industrial Imron? anybody?
