Old 06-04-2007, 10:27 AM
red20 red20 is offline
Default Re: Hydraulic Steering
"P"= Port= Red?? "G"=Stbd=Green??
Old 06-04-2007, 09:23 PM
Correct.
Old 06-04-2007, 09:46 PM
i am just tryin to double check before i mess something up. so the "red" hose goes on the "port" side of the helm and goes to the "starboard" side of the cylinder? and the opposite for green? i have not put any hoses on anything yet because i have no help to bleed at the moment and i am not sure if i need to put and pipe sealing (teflon tape) on the threads or not?
Old 06-04-2007, 09:49 PM
No, port goes to port and stbd to stbd.
Old 06-05-2007, 01:03 AM
i downloaded the pdf instructions from teleflex and the picture shows the hoses crossing thats why i am confused.. thanks for clarifying for me scottm.
Old 06-05-2007, 03:16 PM
Well if that is the way Teleflex says to install them, I did mine wrong. Luckily I have not filled the reservoir yet so it's an easy fix. I'll have to check the Teleflex instructions myself and see if I'm wrong.
Old 06-05-2007, 11:09 PM
what about any kind of pipe thread sealant? did u use any of that? hopefully ill have mine operation by thursday/friday.. ill let u know which is correct if have not done it. if u look at page 48 and 49 on the pdf and it shows the hoses being crossed..
Old 06-06-2007, 11:55 PM
OK here it is!!!! the hoses MUST BE REVERSED!!!!!!!!!!!!
and no pipe thread is needed cuz the hoses have an o-ring in them.. got mine all filled and bled today. didnt take too long. very simple procedure.
Old 06-07-2007, 09:57 AM
So what you're saying is if the red hose is attached to the port side of the helm it must be attached to the starboard side of the steering cylinder?
Old 06-07-2007, 05:13 PM
i put the reds on one side and the greens on the other and the motor turns the wrong way.
