Hi, and thanks for this cool website!
I recently got a '69 seacraft center console with an 80's carbed Merc 200 V6. I know it's way too much engine for this boat, but it's what I got. It gets this little boat going in a hurry, but seems under propped at wot. So I was wondering what size prop you guys that have similar rigs use. The boat is super light with no top, no livewell, no extra nothing and will stay this way. |
19 pitch Mercury Mirage Plus . . . if you carry a heavier load 17 Pitch Mirage Plus will work well too.
![]() Quote:
![]() 200 ponnies is perfect on the 20SF. ![]() When you need to GO It is nice to have...... 21 inch Laser II on the NoBones ![]() PS: Welcome to the site bitsamonkey.. See ya, Ken
See ya, Ken © |
I second that on the 21", I have a T Top and a Master Angler and run a 19 at 5600 so you need a tad more.
Any way you measure it - dumbass is expensive |
Thanks for your help on the prop. Now to the next issue...
The boat has a HUGE tank that takes up the entire console, including the forward seat portion of it. Have you ever seen a seacraft with an external tank like this? Or do you think someone abandoned a bad tank under the deck? It is a '69 and I believe that's the first year for these. It does not have any storage cutouts along the under gunnel liner like all the boats I've seen in your pictures. In any case I'd like to have an under deck tank and a smaller console. |
The older boats had above deck 40 gallon fuel tanks.
no bones and egg what diamater prop are u running? no bones i know ur boat is fast with that merc u have. egg what speed do u get out of yours?
My prop is standard issue Merc SS and not sure dia, my motor is mounted high and I cannot get any trim before it blows out. I will put a Mirage Plus on it for more rake in the blade but my top is a miserable 48/50 with it dragging so much hull, it rides too flat for any top end.
Dixon, have you measured the angle of thrust on your motor at operating trim angle? If you cannot trim at all without ventilating your prop, that means you're probably at a negative trim angle (thrust angle aims slightly downward), and if so, you're running too high out of the water. You need a positive thrust angle of at least 4-5 degrees, or you're literally driving the bow down into the water, creating a lot more drag. You want to get the stern up, then you want to lift the bow for best speed. If you run with your motor trimmed all the way down, put a carpenter's protractor on it and measure the angle to the cavitation plate. If you don't have access to a big protractor, just stick a long level or good straightedge along the keel line of the boat. If the cavitation plate is exactly parallel with the keel line, or the front of the cavitation plate is higher than the rear, you need to adjust your mounting height upward. You need about 10* of negative trim (trim "in") to get on plane, then you should run at about 4*-10* of positive trim (trim "out" or "up") at full throttle.
Common Sense is learning from your mistakes. Wisdom is learning from the other guy's mistakes. Fr. Frank says: Jesus liked fishing, too. He even walked on water to get to the boat! Currently without a SeaCraft ![]() (2) Pompano 12' fishing kayaks '73 Cobia 18' prototype "Casting Skiff", 70hp Mercury |
hi ken, i was wongering what year your boat is and if it came with the rail, mine is a 1978 20' and came with no rail,and i would like to put one on it, great looking boat by the way, thanks mike.
