Old 02-16-2008, 06:43 PM
Default Re: 20 Master Angler 115 ETEC v. 150 ETEC
Hey,
GSF,
Thanks for your previous help!
Now its time for me to help push you over the fence.
Why you want the 150. These points have been made ,but WTH.
1 less stress on crank, bearings , rods ,wrist pins, tranny,
etc.
2 better mpg at cruise.
3 better resale. If I was looking to buy, I would walk away from a 115 sight unseen.
4 Mother nature. When you REALLY gotta go , you can. Even 5 mph can be a day saver.
5 Chicks dig big lower units.
6 size does matter in more ways than I think.
GFS
Old 02-16-2008, 10:32 PM
wildlifeone wildlifeone is offline
i HAVE A 78 MA W A 2007 SUZUKI 175 4 STROKE . THE 150 WOULD BE PLENTY OF MOTOR FOR IT . I THINK YOU WOULD RUN A 115 TO DEATH TRYING TO MAINTAIN ANY TYPE OF STEADY CRUISE.THE FUEL EFFIENCY WOULD NOT BE GOOD EITHER BECAUSE YOU ARE GOING TO BE RUNNING THE MOTOR AT THE TOP OF THE POWER BAND IN ORDER TO GET ANY SPEED.MY 175 IS 3500RPM 32MPH.
Old 02-17-2008, 01:50 AM
I ran an old V-4 115 on my Seafari, which is a fair amount heavier than a MA, for nearly 1000 hrs with zero durability problems. Was still in good shape with good compression when I sold it. Used to cruise @ 4500-4700 rpm all day long. My dealer, D & D Marine in WPB who sold outboards since the 1930's, said "the crank in that motor is only about 6" tall and is good for about 7000 rpm, so prop it to rev and you'll never hurt it. Just don't lug it down." The old 115's were pretty rugged motors. When I bought mine in 1975 I was trying to decide between the 115 and 135 (this was before the V-6 came out), and had one old-time mechanic tell me that a 115 would outlast about FIVE 135's! I believe one key indicator of durability is HP/cu in; with the old carb'd 2-strokes, the less "souped up" engines tended to idle better and be less temperamental.
There is one other argument to be made for a small motor wound up pretty tight - I found that in big following seas with a heavy load, a motor that is already well up on the torque curve will require less throttle jockeying and tend stay up on plane better when you're going "uphill and downhill" than a bigger motor that's normally throttled back more.
Grady SF - I too was concerned with weight when I repowered, even though the Seafari is less stern heavy than a cc/MA. I also considered the 115 and would have probably bought it instead of the 150, but they weren't in production at the time. If you look at the HP curves in the BRP brochures, the "milder" (lower HP/ cu. in) E-Tecs are significantly under-rated - the 225 is really a 240, and the 150 is really a 165! I'd guess the 115 is really about a 125, which would have been a big step up from my old 115 which was really only 90 hp at the prop! 165 HP is a lot more than the 20' hull needs unless you run in flat water all the time and like to cruise at 40 kts!
That said, I'm sure you'll be very happy with the V-6. That exta power is definitely addictive! I have to admit that, although I'm not a speed demon either, it's nice to be able to cruise at 30 kts and carry on a normal conversation! (I have some test data that shows the E-tecs are quieter than the 4-strokes at high cruising speeds because they don't have to rev up as much!) It runs a little smoother than the V-4 at low speed, and might be a little quieter at cruise due to less throttle opening. The 115 is basically the 175 block with 2 cylinders sawed off. Since the cylinder designs are so similar, I suspect the BSFC (Brake (hp) Specific Fuel Consumption (HP/fuel flow) is about the same for both motors. That means at the same boat speed/HP setting, both motors will have about the same fuel flow rate. The smaller motor will have a slight edge because of less throttling loss with larger throttle opening at same HP, but I suspect that's a 2nd order effect that would be hard to find unless you did a dyno test! However, if you choose to use all that extra power in the V-6, you'll pay for it at the gas dock! At optimum cruise on mine, about 23-25 mph/2700-3000 rpm, the I-command gage says throttle opening is about 30% of max, so the V-6 is really loafing most of the time!
Old 02-18-2008, 02:21 AM
GradySailfish GradySailfish is offline
Hey guys, as I said before, its 150 ! I figured I'd like to keep the motor running as low as possible and still maintain a comfortable 22 knots cruise. Doing so will let the engine work easily and efficiently. Below I attached a link for evinrudes test results of what I think to be a comparable package to what my 20 MA is.
Evinrude Test Results
BTW Although I raised the transom, I never raised the splashwell and the drains in the spashwell are only a tad higher then they originally were. Do you guys think this will be a problem ?
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
Old 02-19-2008, 11:34 AM
I still have a 20" transom with flappers on those and never get any water through there, the scuppers are a different story
Old 03-07-2008, 08:01 AM
gordonhg gordonhg is offline
Grady,
Did you get your 150? So far I am really happy with the performance of the 115. I had 4 people in the boat and really couldn't tell much difference from when it was just me alone. I also really like the reduced weight on the stern. I don't have water comming in the scuppers when I stand back near the engine like I did with my 175. My GPS is broken so no real numbers to provide yet..
