Old 08-28-2017, 04:02 PM
Yep.......been there, done that!!
Old 08-28-2017, 06:40 PM
Don, thanks Bamboo sheets are real comfortable!
Old 08-28-2017, 07:56 PM
Ken and Terry, these are not too much money for an use or two on that shag carpet!!!
http://www.homedepot.com/p/HDX-Comfo...630X/203713880
We have those at the shop.
Lots of wimmens come through and we don't want to send them home
lookin` like chicken heads on Broadway.
I wouldn`t bleach nylon as it is mostly solution dyed. Topical.
Olefin may be a better fiber. Recycled plastic bottles.
Some have a unitary backing which has no jute and is more malleable and does not
hold as much water by a long shot. Haven`t seen any samples with the longer nap
as the original which I suspect has better wicking properties.
Old 08-28-2017, 10:38 PM
. . . I think the carpet was done to help wick and dry such moisture but who knows. . .
I actually do know, and I'm sure Connor Davis with his background in the A/C business does too . . . what's going on is that on a real clear night with no wind, there is enough cooling due to radiation that by about 5-6 am, the temperature of your cabin top will have droped below the dew point, which is typically in the mid-70's in Florida with our humidity that's 100% by early morning. So the moisture in the air will simply condense out on any surface that's colder than the dew point, including both the outside and inside of the cabin top, just like it does on a cold bottle of beer on a hot humid day! That's why the morning dew on top of your car is so heavy that looks like it rained overnight even though there wasn't a cloud in the sky! However if you put some insulation (carpet) on the inside of cabin top, that will keep its temperature above the dew point, so you won't get "sweating" or condensation on the inside! As a Florida native that grew up on the New River in Ft. Lauderdale, Carl Moesly understood this better than most folks, so he definitely knew what he was doing when he specified the "mouse fur" for the inside of the cabin top on the Seafari. Unless you live in a real dry climate like So. Cal., I suspect that removing the carpet from the cabin top will actually INCREASE the probability of getting mold/mildew in the cabin! Also, if you don't keep a cover on the boat that will allow you to leave the hatch open an inch or two, one of these solar powered vents installed on the hatch might also help prevent mold and mildew in the cabin.
Old 08-29-2017, 08:22 AM
Eric B Eric B is offline
I place one of these in my cabin when the boat is on the lift. The difference was noticeable within 24 hours. It is not a dehumidifier but dries the air, uses very little power and has no sparking elements.
https://www.amazon.com/Davis-Instrum...e+dehumidifier
Old 08-29-2017, 12:27 PM
Thumbs up
Replacing a girlfriend or wife is always costly !!
My suggestion would be, do not put those girls in a position
that they see the shag carpet while you are in the cabin ...
I know this will keep you on your back, but will save you money
in the long run.
Some good info in here... now I can defend the benefits of disco mouse hair to my lady. Or, as you suggested, just use "avoidance techniques".
The hatch cleaning results came out well. The rest of the ceiling is in excellent shape. It's shrunk a bit over time, or at least the edges have pulled out around the windows and such, but no sagging that I recall. I'd post pics but photobucket and I no longer get along...
