![]() Quote:
Capt. Brian |
It's not about quantity, it's about quality...and the experience. |
Mine was replaced in '04. Mine didn't have that ground tab. It should not make any difference. This new one appears to be the one you can use
![]() ![]() 1978 23' Superfish/Potter Bracket 250HP -------- as "Americans" you have the right to ...... "LIFE, LIBERTY and the PURSUIT of a Classic SeaCraft" -capt_chuck |
#24
Thanks Chuck. I should get the 5" and cut it down, correct?
Also, any special putty you recommend?
#25
![]() Quote:
As far as the putty material, I would make my own with resin & cabosil. If not I guess you could use "Marinetex" or Fasco "Fas-Stone"2 part epoxy compound. Either way cut up some fiberglass strands into it to make it real thick and you'll be good to go ![]()
#26
Thanks Chuck.
#27
Just wanted to follow up on this and thank everyone for their advice. I replaced the brass scuppers, used life-caulk on the new ones and the bilge now only pumps when it rains. It feels like I have a new boat!
The old ones had rotted around the flare under water and must have been letting a lot of water in the bilge. |
