Old 07-20-2010, 10:21 AM
Default Re: Yamaha 250hp 2 Cycle - Bogging Down?
. . The primer pump bulb is sucking shut again, so got to do some more investgating....
That means there is a flow restriction UPSTREAM of the primer bulb, like a plugged filter, plugged screen on fuel pickup in the tank, plugged elbow, etc. Sounds like maybe the "ethanol-fuel-cleaning-out-tank disease!
Check the anti siphon valve on the tank. You can remove it and change it or just leave it off.
Did you check this?
Old 07-20-2010, 11:58 PM
jeff6645 jeff6645 is offline
I don't think I can remove it from my tank. From what I can tell the fuel gauge sending unit is the only thing I can remove from the tank, but I could be wrong, wouldn't be the 1st time. I will take a picture of my fuel tank when I get back in town later this week.
Jeff Pettit
Pettit & Pettit Enterprises
Mobile, Al.
1974 23' Yamaha 250 OB
Love My Classic Seacraft
Old 07-21-2010, 09:00 AM
Yes do that. The Anti siphon check valve should be right in front of the sender. It may be hard to do, but most are just a barbed fitting. It is attached right to the street elbow.
Old 07-27-2010, 01:36 AM
Haven't had a chance to remove the cover and take a picture of the tank... BUT think I got it fixed. Saturday pulled the hood. Found one problem right away a pinch fuel line and then noticed that one of the linkage arms were loose. After fixing these two items it ran much better. Then adjusted the jets additional 1/2 turn out on each carburetor. Tried it again, it ran better than ever!! Hit 48mph quickly with no bogging down out of the hole!!!!
Wow was I excited!
But then the *@$#ing foot locked up!!! Motor wouldn't even turn over. Kept working with it moving from forward to reverse it finally clicked and was able to start the motor but it was hung in reverse!! SO we backed almost 2 miles back to the dock... kind of embarrassing!!
When I got the boat in OCT 09 I changed the foot oil and noticed shavings on the magnet on the drain plug and then changed the oil again a few weeks ago and noticed a few more shavings so I knew there was an issue but I guess I thought it would fix itself
Been pricing lower units found new OEM for around $5,000, rebuilt for $1000 and "used" for $695.... did see one company called SEI that offers "NEW" lower units (not OEM) for $795 with a 3 year warranty. Anyone every heard of them? May need to start a new thread to discuss the lower unit issue.
Jeff Pettit
Mobile, Al.
