Old 08-20-2011, 07:18 PM
Default Re: Is this a sea craft?
So let's say you're 20 miles offshore and taking on enough water to keep both pumps running continuously and for whatever reason, it's taking forever to get back in and your batteries drain completely? Now what?
That's why motors have a thing called an alternator that charges the batter(ies) when their running.
Old 08-20-2011, 08:04 PM
if that does work put you head between you knees and kiss your ass good bye,
I cant do that any more because my stomach is too big.
Good one Doc.
Old 08-20-2011, 09:05 PM
BigLew BigLew is offline
When the pumps can't keep up, you are going for a swim, maybe your last one. Don't try to do anything to save the boat before you get everything you might need to wait for the coasties - Including the radio to let them know how big a bag of doo-doo you stepped in. Then try and save the boat.
See below! ie. buy BIG pumps!!!!
Plan accordingly!
Old 08-20-2011, 09:38 PM
Basspond Basspond is offline
Aside from the whole redundant bilge pump discussion, whenever you are fishing offshore, in the northeast especially where the water is cooler and you are running farther distances than our southern friends, it is a good idea to have a raft on the boat.
I used to fish my 20 SF 30-40 miles off on nice days here in NJ without a raft and didn't think much of it. Now as you get older and a little wiser I don't go offshore without a raft in the boat. I have my epirb/plb, raft, hand held vhf, and a lot of my friends are going with sat phones as well now due to the long distances we fish. You don't even need to buy one yourself, find a friend that has one that you can borrow, or just let them fish with you for free [img]/forum/images/graemlins/tongue.gif[/img]
2001 23 Regulator 2006 F250 Yamaha
Old 08-20-2011, 10:39 PM
Hotwire your pumps. Be independant.
Cheers,
GFS
Old 08-21-2011, 08:24 PM
If the possibility of sinking or capsizing arises, first have everyone put on a PFD. Then grab your survival equipment and supplies and have ready to send over the side. Only then should you stop to call for help.
I STRONGLY recommend a small cooler for your survival stuff. I use a 32 qt Igloo in bright red. It floats, and is relatively water-tight.
FTR, I have 3 bilge pumps, 2 aft and 1 forward. I have a 1500gph fore and aft in the boat, mounted about an inch above the bottom of the bilge. I have an electronic auto-only 500 gph mounted right at the bottom of the bilge aft. Normally, it's the only one that ever comes on, except when I'm backing down, or launching at one particularly steep ramp where the transom gets submerged.
I am not happy with my Rule 1500's. I have had to replace three over the past 4 years, and the bow pump I have now is 2 years old and not working. My replacement pump (not yet installed)is a Swedish-built Johnson 2200.
Old 08-21-2011, 09:20 PM
76Red18 76Red18 is offline
I've had problems with the rules also. Also went with johnson. 2- 1500's with auto switches and manual override, each on their own battery. Also have a 750 auto in the built in floor "baitwell" to get rid of the water that runs off the deck when I have my splashboard drain plugs are in. Pretty good system to keep the bildge and deck dry.
J. M. Hendrix
Old 08-22-2011, 10:04 AM
Trayder Trayder is offline
Velvet Jones
My weekend project after reading this:
1: re-wired both bilge pumps, new switches, wire, floats etc
2: I put in a high water alarm
so sorry for Mitch's loss but it was a wake up call to add some insurance items on the rig.
Old 08-23-2011, 01:11 PM
KenB KenB is offline
Quick question about the rule pumps burning up... is this something new? Or have they always had a failure rate? I thought you used to be able to show up at their factory with a burned up pump and get a replacement, no questions asked.
Old 08-23-2011, 02:35 PM
Those days are gone, my friend. Warranty is one year now.
