Old 05-04-2013, 09:07 PM
jongolds jongolds is offline
I would normally agree. That's why I've never used it before but the bracket had already been attached using 5200 so there was no going back anyway.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 05-04-2013, 09:30 PM
I love 5200. I can trust it. Mount your 500# motor with 5200 and wait a few days then take all the bolts out. The motor wont budge. You will have to rip off the paint and probably a little fiberglass to get it off. Not a problem if you are good with fiberglass. When I cut a 3" hole in the bottom of my boat and mount the transducer I know it is never going to leak or come loose.... That's a good feeling. I once spent 1/2 a day trying to remove a thru hull transducer mounted with 5200. Air chisel, hammer, crow bars etc... finally got it off. I love that chit
Old 05-04-2013, 10:05 PM
Originally Posted by joshmon71 View Post
I never use 5200. at some time that bracket will come off. then the swearing starts. been there done that on transducers below waterline. I use 4200. or life caulk. its done now hope it solves the issue.
Life caulk with 80# mono beneath is takeapartable. Put the mono in tight around the bottom curve inside ending at one O clock on the bracket.
