Old 11-27-2013, 04:23 PM
conchcuzzy conchcuzzy is offline
Default Laminating new transom
Laminating the new transom prepping the stringers. Close up of prepped transom show screw pattern. Screw's will be used from the inside and outside to draw laminate together and squeeze out air.
Old 11-28-2013, 11:27 AM
Default Fuel tank, transom, and the beat goes on...
Fuel tank is good. No leaks, no oxidation. 50 gal capacity, custom 3/16" welded aluminum. The tank was sealed with zinc chromate prior to installation so foam should be ok to use (though I do prefer coal tar epoxy...)
On a separate note, I have received lot's of feedback on raising the transom, both for and against. The main reason I chose to maintain the 20" transom, besides preserving the classic design, is keep the center of gravity lower = better ride. Can anyone provide a persuasive argument for raising the transom to 25"?
Old 11-28-2013, 11:31 AM
Plywood is in.
Old 12-07-2013, 01:02 PM
Default Dry fitting deck
Dry fitting the plywood template for the new deck. Fiberglass tube for clean access to the chase and keeping water out.
Old 12-09-2013, 08:58 PM
Default Bimini top measurement
Was able to get access to measure the Bimini top today. The canvas is Sunbrella. 8 years of Florida summers and it still looks new!
Old 12-10-2013, 08:36 AM
erebus erebus is offline
Nice!
So just to confirm, thats 77.5" between the uprights and approx 65-66" for height?
If you get a chance how long is the canvas when its fully open fore and aft?
And thats a four bow right?
Zachary
Old 12-10-2013, 09:08 AM
With the 20" transom, the motor sits mighty low in the water. The hydraulic steering and all the rigging wires and cables are under water in the splashwell while fishing, (me at the helm and 1 fishing buddy in the back fighting fish).
If this doesn't bother you, then proceed as you planned. Good luck!
Old 12-10-2013, 11:30 AM
Uncleboo, thanks for sharing your advice and experience. Perhaps there is a difference in how our 18s are rigged and/or transoms configured, but I have not had any of the issues you describe. Fishing blue water with over 1,200 pounds of guys and gear on board the rigging stays dry and my hydraulic steering is above water. This may be due to the jack plate I use. I will get closeup shots of my transom and rigging to better illustrate.
Old 12-10-2013, 11:39 AM
Zachary, that's correct 77.5" between and 66" tall. I will confirm the width measurement today making sure the uprights are not squeezed or spread. Bear in mind the 1978 18sf has wider gunnels than earlier models so you may need an inch or two wider Bimini frame to depending on your configuration. I will also get you the open measurement.
Old 12-10-2013, 03:32 PM
I'm very interested in seeing your pics. I'd like to see one of the stern with the motor all the way down and one from the side. May just give me some ideas. Thanks!
