Old 03-15-2014, 07:10 AM
fishlips56 fishlips56 is offline
Ryan, I was talking to my merc mechanic and he thought it might be a stator problem. Did the motor shut off while running, or did it fail to restart after you had shut it off? Only real problems I've had with my merc's have been stators and switch boxes. As a precaution, I make a habit of not shutting my motors down when I'm offshore, unless I really have to. When you checked for spark, was it while the motor was cold or hot? When you said it had fuel, did you try to start it by squirting a little fuel mixture directly into the carbs? Good luck with the cure, the weather is starting to turn up here in Central Florida and the winds should start laying down a bit.
Barry
Old 03-15-2014, 07:15 AM
shana shana is offline
check kill switch
george j victor jr
Old 03-15-2014, 12:00 PM
Ryan Ryan is offline
Thanks for the replies fellas turned out to be the ignition switch. mechanic has a new one coming and I should be all set. cant waut to run her a little more.
