Old 04-07-2016, 07:29 PM
pelican pelican is offline
when I had my shop:
ONLY tank manufacture is used was patriot marine,waretown nj
it was always a turn around of right about 2 weeks,at the most !
EVERY tank was PERFECT ! WEMA fuel sender / pick ups were provided
i'd run up,drop old one off and pick up the replacement
very simple process !
the more I learn about supplies/parts in florida - the more I shake my head in disbelief !
Old 04-08-2016, 08:20 PM
Originally Posted by pelican View Post
when I had my shop:
As I said when we first met, you must get word of mouth recs for everything.
So, the chat with the builder was fun today.
Why did you use brass elbows soldered to copper pick up tubes in aluminum?
I have been doing this for 30 years.
So you have been making batteries for 30 yrs?
I have had tanks come back after 25 years and you can always remove the fittings.
You cant do that with aluminum.
Have you heard of Tef Gel?
No.
Great stuff for dissimilar metals like SS and aluminum.
You mentioned that.
Did you pack the tank for shipping?
No one of my guys did.
The pallet was 1/3 the length of the tank and then wrapped in cardboard and 2 straps.
I made a claim with the shipping company.
What was wrong with the way is was shipped?
I`ve shipped tanks cross country that way and never had a problem.
This was just cross state.
It looks like the fill fitting got pushed down and the fill hose will lay on top of the tank
and rub the epoxy off the corner and top of the tank.
Well the 90 cut may not be exactly perfect.
It would be 2 45 cuts and that is kind of important as rubber has a high carbon content.
Can you send me pictures?
Not until Monday, the tank is at General Sheet Metal getting new pickups.
Why are you getting new pick ups
I don't like galvanic corrosion.
I have never had a problem and I have made thousands of tanks.
You can`t get aluminum pickups out. Mine come right out.
I got my 26 year old PU out with just a wrench and some muscle.
No heat. No penetrating oil. I`ll send you pics Monday.
Old 04-09-2016, 10:45 AM
Oh Boy. That seriously sucks. Sorry Bro. My buddy is a professional welder (over 30 years, haha). He took a serious look at the tank I removed from the 79 MA. Says we can do this. Need to find supplier of all fittings. Dismantle old, or original?, to learn about baffles. Then pressure test to 5 pounds have it Robert Certified. That's the plan. Good luck Sandy. Convo with your builder makes for a better read than Saturday morning cartoons!!!
Vezo
Old 04-09-2016, 11:32 AM
Vezo
Well, I am a walking cartoon and can voice many of our favorites.
General has given their blessing on the welds and work done.
They will make it what I want and are a pleasure to work with.
Mine was tested at 5 lbs. General said 2-3 is fine.
They didn't like plug welds on top of the baffles but said they would not
cause corrosion issues...
CG said there is no ABYC on rec boats, but they would flag his pickups on
any for hire vessel. Only alum or ss is Comm ABYC.
Old 04-09-2016, 11:48 AM
Hey Bro, think he might sell you two pickups, one sealed, a 90* fill, vent and sending unit mount, all Aluminum for my new tank? That'd be friggin awesome.
Old 04-09-2016, 11:49 AM
If he wants to sell a GOOD sending unit as well, would need to be about 7.5 inches, same for each pickup.
Old 04-09-2016, 11:56 AM
use a WEMA sender - NEVER had one fail !
ANY good welding/fabrication shop will be able to make up pick up tubes - from aluminum...
me,i like internal pick ups !
Old 04-09-2016, 11:59 AM
tank coating:
clean,scuff sand,clean again,followed by a chemical etch prime,then coat it in interprotect 2000 - correct thickness.set the tank on strips of starboard."rough up" the starboard and glue it down to the hull - AFTER you test set the tank,to determine if the tank sits level....
this is the way to go !
Old 04-09-2016, 12:49 PM
tank coating:
They did etch ,prime, and coal tar epoxy
The p ups just raised a big red flag.
And the shipping
Old 04-11-2016, 09:25 PM
Put a v notch in the bottom of the pickup.
