  #31
Old 04-09-2005, 03:42 PM
sailcat sailcat is offline
Default Re: 200 hpdi on a 18
Butch, I put the seastar hydraulic on my 20' when I installed the 200. It's amazing after having cable. One finger steering and straight as an arrow when you let go of the wheel. No torque push at all.
Bob
72 20'CC
Old 04-09-2005, 07:33 PM
ocuyler ocuyler is offline
No, only whiplash...
Otto
Old 04-10-2005, 06:10 AM
Otto, Look at the pictures you took at the CSC gathering.
Notice Rodney hanging onto the same post the whole time,
never left the spot. I have his hand inprints in aluminum. [img]/images/graemlins/wink.gif[/img]
Bob
72 20'CC
Old 04-10-2005, 06:44 AM
bigblockdock bigblockdock is offline
Bobber, No torque, I would not know how to act!!! When I had the bass boats, hydraulic steering was not being used except in work boats and larger crafts. You needed to let up on the throttle to make a left turn! I did not think about steering torque when I put the 150 on. I does just fine at cruising speeds with little trim but when you start to put the hammer down and add more trim, the torque comes in big time. I've driven a 42 ft. charter boat with hydraulic steering and it was nice, just a few more turns on the steering wheel to go left to right. Did the orig. steering wheel work on the new system? I'm seeing prices in the area of 700 to 900 dollars for the systems. I have a relative who has been nursing a worn out cable on his boat which has the same size and type as mine so maybe he will buy it if I give him a good price. I put it in the SC the same time I put the 150 on, 2 wks ago. Any idea's as to where to get the best price on a system? Butch
1985 seacraft SF18 with 97 merc 150 EFI
1988 shadow bass with 200 Johnson GT
74 searay 240V with modified 351 Ford/Mercruiser.
One is not enough!
Old 04-10-2005, 07:30 PM
As long as you have a half moon key in your wheel it will work. But to get better response I went to a 13" wheel and a suicide knob. Also went to the inside hole on the motor. It seems to be about the same as with cable.
I forgot where I got it from but the seastar is about $650. Look around and you may find them cheaper. Mine had everything including the oil.
I had to do a little modification on the splash well to help when I tilt the motor up. Just not a whole lot of room there.
Bob
72 20'CC
Old 04-17-2005, 08:19 PM
Thanks for the info Bobber, I'll check the local marine supply places, we have West Marine and Boaters World around here. I use to work at a local marine dealer and my son is doing a work study there for school so I'll check there also. We used the boat today to go flounder fishing in Va. and did not need to worry with the trim or top speeds because it was 35 degrees when we put in. You got to love huh? didn't do much as the water temp was 47 degrees, down from 56 last week. It warmed up fast and the ride in was better that the ride out! Hope to raise the motor one hole by next weekend so we can try that out if its alittle warmer. Butch
One is not enough!
Old 04-17-2005, 08:46 PM
Finster Finster is offline
Yo B, you may want to look into a bigger trailer... [img]/images/graemlins/crazy.gif[/img] [img]/images/graemlins/grin.gif[/img]
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 04-18-2005, 04:54 AM
Fin, By the time I get done loading 5 days worth of fishing, diving and wakeboarding to go to the Keys. It is a wonder I don't need 3 axles. And I got a heck of a deal on this one. [img]/images/graemlins/smirk.gif[/img]
Bob
72 20'CC
