  #31
Old 01-22-2008, 12:14 AM
htillman htillman is offline
Default Re: Advice Need...Getting Ready to Start Restorati
Looks like you are making headway. I sent you a PM, check it out and let me know if you are interested. You are doing much the same type work I did and this helped me more than anything else I tried.
Old 01-22-2008, 01:04 PM
Yeah I have been having some trouble getting the resin to harden with the cold/wet weather!
Old 01-22-2008, 06:46 PM
natchalkley natchalkley is offline
I was having the same problem up here in VA until I got a propane tube heater. they are $100 at Wallyworld and they work great. just make sure that you dont put it too close. If it gets too hot it tends to do weird stuff to the resin.
Capt. Nat Chalkley
Get the Net Charters
http://www.gtncharters.com
http://www.getthenetcharters.blogspot.com
Old 01-23-2008, 10:09 AM
hermco hermco is offline
Wallyworld?
Old 01-23-2008, 03:26 PM
nestorpr nestorpr is offline
I think you should reconsider the bracket and keep the boat as original as possible with a notch for the OB, it would look awesome with a 200-250hp unit from one of the big outfits!
Boatless again!
Old 01-23-2008, 03:38 PM
Default Keep it original !
Well if I reconsider I would stay with I/O. I am certain I do not want to reconstruct the whole transom to notch it,splash well and the works.
Old 01-23-2008, 06:15 PM
BigLew BigLew is offline
Wallyworld?
I think he is referring to Wal-Mart.
Plan accordingly!
Old 01-23-2008, 06:56 PM
Wallyworld?
thats the one.
Capt. Nat Chalkley
Old 01-27-2008, 07:53 PM
Default Stripped Out!
Over the weekend got some work done on the "21".
Took out the overnighter boxes and the Jockey Boxes. The boat now has gone from a weekender to a Sportsman. All that is left is to remove the last two sections of floor and then start the rebuilding process.
One box gone.
Underneath shot of V-Bunk.
2 boxes gone.
Rear Transom shot.
You know a Mercruiser 350 is looking better all the time.
Old 01-28-2008, 01:24 AM
3rdday 3rdday is offline
Default Re: Stripped Out!
looking good !
Ya know VW has a 265hp turbo diesel out.......Hmmmm.
