  #31
Old 01-08-2011, 12:25 PM
swampdonkey swampdonkey is offline
Default Re: 74 Center Console 3/4 Restore
Hi LL, I'm new to the forum. I just purchased a 23 SC myself and I am eventually going to replace the transom and add a bracket. I love the seat up you came up with but I think it is beyond my abilities as this will be my first attempt at anything like that. I see you are from Greenville. I went to ECU and don't live too far away. Any chance you would want to make some extra money and do another molding of your transom/seat? Thanks! Boat looks great!
Old 01-08-2011, 03:36 PM
Awesome Job!! Especially the rear seat/cooler/baitwell.
Old 01-08-2011, 04:44 PM
KenB KenB is offline
Sickie Brah! Dank Boat!
Came out great.
Old 01-08-2011, 06:26 PM
Very, very nice!!! A few questions... Did you mount the Hermco bracket where he recommends?? Did you experiment and arrive at the bottom engine mount hole?? Is it a 30" engine?? Thanks man!
Old 01-09-2011, 10:27 AM
LadyLuck LadyLuck is offline
swamp,
i have been working on this one for about a year and a half...my wife has had enough for a little while
it would be great to get together and i can explain what i did...its not that difficult...i also have a couple guys here in greenville that work at a local boat company that helped with some of the grunt work, at a good price..instant message me your phone number and maybe we can get together...
REEL, i mounted the hermco exactly where Don said to put it...the instructions that came with it were very easy to understand...only mistake i made during installation was i temporarily put 3 bolts on to hold it while i tweaked the other holes...the lock bolts stripped (put them on with air wrench) and it was a real b getting them off...otherwise, was pretty straight forward...
the engine was mounted on the center holes to begin with, when i put it in the water the first time the anti cavitation plate was splashing water everywhere...i lowered it to the bottom set of holes to get the engine as high as possible and that solved it...
it is a 30" on Don's twin bracket...did that with his recommedation for flotation purposes..
have you seen my post on scuppers? that is really the only issue that came up after rebuilding the transom and adding the bracket...since you already have a bracket, you are probably already aware of this...
take care..
Tim
Old 01-09-2011, 11:41 AM
Tim,
Beautiful work. That transom cooler seat is an inspired addition to the functionality of the boat. I like the switch panel too. Is the lettering done with stickers, or is it engraved?
Dave
Blue Heron Boat Works
Old 01-09-2011, 12:46 PM
castalot castalot is offline
Dave
as far as i know all of the panels are engraved and you should see the backside of them but he dosen't want them published for fear of people making cheap coppies
after seeing your boat in the water i know i'm in love!!!
Old 01-09-2011, 02:50 PM
swamp,
take care..
Tim
Thanks Tim, I'll PM you my number. I would appreciate any tips you could pass on!
Old 01-09-2011, 06:28 PM
Thanks LadyLuck. It looks like you kept the original scuppers. Did the short Bennett cylinders mount under the bracket flange??
Old 01-09-2011, 07:09 PM
scott made the panel for me..his website is here:
http://www.vectorled.com/
he does good work.. learned about him a long time ago on this website...the panel is engraved and backlit..i will post a pic soon.. need to order early..it takes some time..
reel, small tabs fit perfectly on the bracket hinge on the rear...i did find out after purchasing the smaller bennett tabs that they will exchange larger ones for smaller ones for free i believe..if you want me to post any particular pics, let me know..
tim
