  #31
Old 12-10-2013, 06:51 PM
erebus erebus is offline
Originally Posted by conchcuzzy View Post
Bear in mind the 1978 18sf has wider gunnels than earlier models so you may need an inch or two wider Bimini frame to depending on your configuration.
They do?!
That's a weird production change. Wonder why...
I already thought the gunnels on my 1975 were pretty wide.
Interesting factoid nonetheless.
Anyway, thanks for the measurements!
Zachary
Old 12-14-2013, 06:32 PM
conchcuzzy conchcuzzy is offline
Zachary, I will measure the gunnels just to be sure. The actual width of the Bimini top is 77" not 77.5". Stainless steel frame, 4 bow, maker unknown. Sunbrella canvas.
Old 12-14-2013, 06:39 PM
Checked, sanded and sealed the tank with zinc chromate. Reinstalled tank with new lines and removed old wet foam.
Refilled and capped rear of stringers that had been cut-out and left open before!
Old 12-14-2013, 06:47 PM
Outer skin laminated in transom.
Old 12-15-2013, 10:52 AM
Here's some "before" pic of the transom. Cropped kind of tight, but you can see everything is well above water line. I will get some after shots with a wider angle view...
The trade off with the 18 is the deck is very low, basically at the water line. The positive of this is that the 20" transom leaves about as much above the water line as a 25" transom does on many bigger boats. If I had a 20, 21, 23 or larger I would definitely raise or enclose the transom.
Old 12-15-2013, 11:32 AM
Tight lines
Old 12-11-2021, 03:44 PM
Default 18' SeaCraft | 2021 Update
I haven't posted in "awhile" lol...
We ended up replacing the deck, replacing the transom, replacing all of the rigging and electrical, rebuilding the stringers, sealing the fuel tank with epoxy paint, installing new Garmin, installing JL audio marine speakers with a JBL Bluetooth head unit and amp, adding 4 additional rod holders, adding under gunwale rod storage racks, rebuilding the hydraulic steering (with new lines), and replacing the helm. Here's some pictures:
Old 12-12-2021, 06:35 PM
Default 18' SeaCraft | 2021 Update pt. 2
Since completing the repairs and upgrades mentioned below, she's offered 8 years of pure enjoyment. This year it was time to continue the process...
Old 12-12-2021, 06:44 PM
Default More photos
It was time for a fresh coat of paint
Old 12-12-2021, 06:45 PM
Default More photos...
This one didn't attach before
