  #31
Old 05-12-2014, 02:51 PM
htillman htillman is offline
Sounds like an interesting project. Really interested in seeing how it turns out.
Old 05-12-2014, 09:38 PM
dginge dginge is offline
Default Great idea
Sounds awesome.
I can't wait to see the end result. Please keep us updated
Great talkin to you today.
Thanks for the knowledge
Old 05-21-2014, 07:17 PM
dave s dave s is offline
Not a lot new, but lots of rain and now wind- ruined my canopy.
Took me quite a few more hours, and grinding discs, to remove the rest of the epoxy and get down to clean glass.
Sanded it all down also.
Ground out small white areas in the original roving; looked like they weren't filled with enough resin in the original layup. You can see lighter areas near the transom. And some small voids near the strakes and outer chine.
After considering, cutout, bracket, euro, and even a shroud, decided that the extension was the way to go.
Cut both stringers forward about 24" to give
me at least 18" overlap for the layup.
Also had to remove foam from the starboard stringer due to an ants' nest that had drilled throughout.
Overall the stringers are in good shape other than some holes someone drilled in the tops.
Now to make/attach the forms, but weather is finally nice, so I'm going fishing next few days.
Old 05-21-2014, 07:19 PM
Another pic- all cleaned up.
Old 06-12-2014, 07:34 PM
Got the subframe built; used a 4x4, 2x4s, and a 5x4 sheet of Melamine board- it's set at 12 degrees.
Old 06-12-2014, 07:36 PM
Filled in some old thru hull holes, a strake, and cuts in the hull.
Beveled the glass back, laid some cloth on the outside and then thickened epoxy with cabosil and glass fibers and a bunch of 1708 layers on the inside. I'll go back over the outside spots when I do the exterior hull.
It's thick enough that I may put the seacock valve back at the same spot, esp. after the glass for the extension goes on.
Old 06-12-2014, 07:40 PM
After doing some testing, I'm concerned with the condition of the original woven roving; most of it seems dry and chalky white.
So to make some more work, I chiseled off much of the roving for about 24", to get some clean glass to bond to.
It came off fairly easily, compared to the leftover epoxy on the transom area.
What's a few more hours?
I hate grinding!
Old 06-12-2014, 07:41 PM
Glass cleaned up; I'm ready to finish the mold.
If only this rain would stop.
Old 06-17-2014, 02:17 PM
Mold almost done. Lots of carpentry work- almost fun!
All done with a cordless circle saw, straight edge, and angle finder.
Need to add keel section, cut off screws, and then do clay and wax.
Want to double check height of sides of tub. It's about 19" now, so should be right height, may need a bit more for the glass work.
With swim platform I'll be about 20" and I have 5-7" more for the motor mount lip.
Old 06-17-2014, 05:59 PM
I have a project 20 that I'm thinking of extending similar to what you're doing. My thinking at this point (at least one boat project away from starting on the 20) is this:
  • Cut a piece of melamine board to match the outline of the transom.
  • Turn the hull upside down and spray the aft 3' with PVA mold release.
  • Spray the inner face of the melamine with PVA and screw it to the transom.
  • Spray the aft 30" or so of the hull with tooling gelcoat and then lay up some mat and roving with some plywood stiffeners laid up in strategic locations. The layup will need to bond to the outer surface of the melamine board so it becomes the aft part of the mold.
  • After cure, break it loose, flip the hull right side up, cut out the transom and prep like you've done.
  • Then attach the mold so it extends behind the transom the desired amount.
  • There's more detail, but you get the point.
For this to work, the steps in the hull have to be parallel all the way back. I haven't measured to confirm this, but they look to be. Not sure if this will be less work, or have better results than your approach, but it's what I was thinking of doing. More than one way to skin a cat...
Dave
Blue Heron Boat Works
