  #31
Old 06-14-2017, 07:34 PM
Originally Posted by Parker Yacht View Post
I thank everyone for their compliments.
Even though we have done a few of these, each one has someplace special with me.
This one is just, nice.
Not complicated or over done, just nice.
She looks...familiar.
What did you think of the glass work in her?
Where did you put the clamshell pickup for the LW?
Batteries taking up precious cold beer storage?
Old 06-16-2017, 08:52 AM
Parker Yacht Parker Yacht is offline
Look's fine, she was actually in pretty good shape, glass wise.
Aft bilge, offset portside center line.
Lifejackets, new mo betta cooler under seat, Rigid Frigid.
Old 06-23-2020, 06:51 PM
Jacktyler820 Jacktyler820 is offline
What made you guys make the decision that the stringers didnt need to be replaced. Is there a way to check to see if the stringers are bad or check and see if they have wet foam in them if they do have foam. Boat looks great
Old 06-23-2020, 07:12 PM
I dont know how often Ole checks this site...The stringers in this particular boat are foam filled and you can see where they have them fully exposed in the first few pictures..they would have most likely checked for water intrusion into the stringers by visual inspection and if still not sure then drill a couple test holes down near the bottom and check for weeping. Water in the foam in these old boats will settle at the bottom of the stringers...It's quite a chore to get out the old foam on these boats...
since they made me a moderator I feel that I have to post more often now lol
Old 06-23-2020, 07:30 PM
Thanks for the reply, that makes sense. Im working on a game plan just tryin to see where im starting lol. Thanks for the feedback.
Old 06-24-2020, 10:02 AM
...since they made me a moderator I feel that I have to post more often now lol
That's what you get for being so good at what you do!
Old 06-24-2020, 12:03 PM
Potter told me one time. You can drill a 1" (easy size to plug up later)hole at the bottom aft. Insert a 1"Dx12"L Nylon piece of rope, therefore creating a "Wick System" for absorbing any water within the stringer & draining it into the bilge. I always hated raising the decks which puts more pressure against your knees aft plus safety is compromised with low gunwhales. Proper deck drainage (wet feet) is not hard to correct the existing thru deck scuppers. Carl Moesly's "Criss-Cross" out the transome is just one of the fixes.
