  #31
Old 04-24-2019, 09:55 AM
Bandit91 Bandit91 is offline
20" transom, 20" shaft and I raised the transom 3". 2-1/4" would have been better due to hydraulic steering head, but, I have it worked out. I went with the 3" jack plate solely for the purpose of adjusting the height of the motor without removing bolts.
That sounds like a good setup. Are your scuppers completely submerged when the boat was docked?
Old 04-24-2019, 03:52 PM
Not now, 2-1/2" above waterline. Before the diet, the bottom of the scuppers was at water level.
Old 05-01-2019, 11:45 AM
Just giving everyone an update. I had pretty much made my mind up I was going with a 140 Suzuki. Went to the local dealer and was not really impressed with them. Didn’t want to be tied to them if I ever needed any warranty work. So long story short, I ended up working a deal on a new mercury 115 pro xs with command thrust lower unit. I really like the dealer I got in touch with and feel like this will be a great motor for the 18. It’s about 363 lbs so almost identical weight to the 130 2 stroke I removed. And with the command thrust lower unit I’ve got plenty of prop choices so I should be able to get it dialed in perfect. I appreciate everyone’s help and I’ll be sure to post up the performance of the new motor along with pictures after I get it installed.
Old 05-02-2019, 11:59 AM
Good Luck with the new motor. It is soooo important to get a good feeling from the dealer who will service the motor later...sounds like you made the right choice.
Old 05-02-2019, 12:32 PM
I have the Yam 70 4S on a 17' War Eagle and absolutely love it! That said, I wouldn't want it on a 18' SeaCraft.
Old 05-02-2019, 12:33 PM
Well done Mr. Bandit!!!!
Old 05-03-2019, 04:28 AM
Beaver Beaver is offline
Nice!!! Please post some numbers after you get a chance to run it a while.
Old 05-05-2019, 08:40 AM
cane cane is offline
Default SF18 Props
What size propeller are you running with 90 HP and 115 HP ?
Old 05-05-2019, 02:11 PM
Not sure about the 90s but I know with the 115 command thrust motors a lot of guys are running 14.25 x 21 pitch props on similar sized boats. So I’m going to start with that and see how it does.
Old 05-05-2019, 09:32 PM
How much did the ride and min plane speed improve?
