Closed Thread
  #401
Old 10-31-2007, 12:55 PM
BigMike8o9 BigMike8o9 is offline
Default Re: Here We Go Again
Joey, love your site. Sent an email.
BigMike
www.bigmikeslures.com
  #402
Old 10-31-2007, 02:58 PM
76Red18 76Red18 is offline
Nope, mines the standard one.
J. M. Hendrix
  #403
Old 10-31-2007, 03:15 PM
hermco hermco is offline
The rub rail is installed. taco Marine part # V21-9613 It's rigid vinyl with a ss insert.
Since I was working alone I used ladders to hold up the ends of the 20 foot pieces while I screwed them in place.
Me and my ladders have done many a rub rail! They work cheap!
  #404
Old 11-08-2007, 01:50 PM
Your lucky Hermco, my ladders went on strike and then stole all my tools.
BigMike
  #405
Old 11-10-2007, 05:58 PM
warthog5 warthog5 is offline
In the past when I've pointed it toward the bow I've had a problem with water being forced into the system when under way and overflowing the bait tank. Well see how this works. Maybe I should have pointed it sideways
HeHe
Actually you may find that it will create a vacuum with it pointing backwards.
The seacock is the answer to slowing down or stopping water flow into the tank when not wanted or to much.
  #406
Old 11-10-2007, 07:52 PM
Some larger yachts have a pull out plug on the raw water intake for the engine as an emergency bilge pump. The intake facing aft will do as well while you can still make headway.
  #407
Old 12-11-2007, 08:07 PM
mbo_1971 mbo_1971 is offline
Chuck - whats the latest here. Didnt think we ever got a final wrap-up on this one.....
  #408
Old 12-13-2007, 12:36 PM
I have not been doing much on the boat. The LP is almost finished. I will resume work sometime after the Holidays and post then.
  #409
Old 01-16-2008, 03:33 AM
Hey Chuck any updates on the boat? also what hatch did you decide to put in your console?
36' Yellowfin
1972 20' seacraft 140 suzuki
  #410
Old 01-18-2008, 10:51 AM
The 20sf project has been moving along at turtle speed over the last few months. Other important obligations that needed attention have been attended to and taken care of and so the boat has had to take a back seat for a while.
When I left off I was in the process of making a fiberglass leaning post that will incorporate a Kodiac live well internally. Here it was curing in the mold:
The mold was made out of 3/4 mdf. A heavy coat of wax was wiped into the mold and then PVA was sprayed over the wax.
Two layers of heavy matt and 4 layers of 1708 were used in the lay up. The corners were all reinforced with 6 inch 1708 tape. As I was laying up the matt I began to see alligators appearing.
I dont know what is worse having a part stick to a mold, which requires scraping off the mold from the part or having lots of alligators to fill and sand smooth. This part ended up having tons of alligators....a result of using too much wax and the pva. You can see the alligators in the pic's below:
Fast forward after many hours of sanding, fairing, priming and finally painting;
The fuel hatch is sealed and screwed in place and the rigging is run up through the deck;
The hydraulic steering is mounted and all the lines are run thru the transom;
This is what the door will look like in the cc. Marine connection has these. The cc has been secured to the deck.
Blue Seas battery switch;
Inside the consel;
Low tide in Alaska;
I will post again as it nears completion.
Closed Thread
