  #451
Old 10-27-2013, 09:12 PM
Thanks Terry but that's not enough time I would rather rent that house again and stay for 10
Old 02-06-2014, 09:06 AM
Default Never Done
Basically the boat is finished...LOL Right!
Anyway thought I might post this mod...in case no one else has thought of it or needs it.
After a few trips out in bumpy water I noticed that the front v-hatch was jumping out of the rail where it sits. I did not hinge it originally (dumb) because I thought I would not use it much (life jacket storage) and that I could just open and slide back to retrieve stuff. Well I was wrong
I wanted to hinge the lid and then have something hold it open while I was digging around. Best solution to date was 5200 hinges to the liner and to make a hinge that would flap one way and lock another. Hope this makes sense.
[ATTACH]
[ATTACH]
[/ATTACH][/ATTACH]
Old 05-03-2014, 12:13 PM
Default Rod Holders
After going out a few times I discovered that I was in need of some rod storage areas . I did not want to put them on the inside of the gunnels for the obvious reason... so this is what i came up with.
One piece of cypress left from the side boards.
Drilled and Varnished.
It has worked out well so far.
Old 05-15-2014, 10:00 PM
What a great job and phenomenal finished project! Haven't been on the site for a while but first thread I wanted to check out. Enjoy! You've definitely earned it......
Will
Old 11-14-2015, 06:34 PM
bgreene bgreene is offline
Would like to see video of the boat running into 2'-4' chop from your boat AND other boat so we can see how it runs .
Would likely be the only video in existence of this hull running in chop, not just flat or near flat calm seas.
Sure it's asking a lot, but would be an interesting piece of nautical history, brought back to life by you !!
Congratulations. Terrific looking boat.
Old 11-15-2015, 09:35 AM
There is a lot of ifs in that request...but if it happens I'll let you know...
Old 11-15-2015, 10:14 AM
Looks great! And im sure it runs great!
Old 09-21-2020, 01:07 PM
M A M A is offline
Hello this vessel looks similar to my HiLiner Gypsy 222 and I’m looking because the capacity plate is missing and I need a picture of one so I can make one. Do you know if your boat is the same hull?
Old 09-21-2020, 02:46 PM
Sorry but it's not even close to the same hull. I like the HiLiners but they are a completely different boat.
Old 09-23-2020, 05:31 PM
you bet
