  #41
Old 03-27-2012, 07:59 AM
fdheld34 fdheld34 is offline
Default Plywood core question
I am going to recore all of my hatches this weekend.. I am going to use 1/2" plywood for the core material and poly. I have seen where others have used plywood in full sheets, as well as small squares. I am thinking small squares will be easier to work with and easier to bond as well (from a search on this site). Any other input appreciated!
-Fred
Old 03-28-2012, 08:21 AM
-Fred
You are right on all of the above...if you do not have the plywood yet then I would use 1/2 inch plascore. Not that much more than plywood and you can get it scored so it will conform to the hatch.
Old 03-28-2012, 11:59 AM
Terry
Darn it!
I already bought the plywood last night...will hotcoat it all etc...
Hopefully it will last another 33 years!
-Fred
Old 03-28-2012, 08:18 PM
After work today I was able to remove the rotten core of my fuel tank hatch. Because I do not have an air chisel..I removed all by hand...
Pics showing removal of rotten core....and the owner making sure I do a thorough job!!!
And a picture per the owner's request....
Old 03-28-2012, 08:21 PM
After my arms fell off and the chest pains subsided, as well as, changing the owner's outfit... because he decided to play in the water hose..I broke out my angle grinder with 80 grit and was able to remove the remaining core from the hatch without any trouble....now I know how Don Herman feels!!!
Old 03-28-2012, 08:23 PM
Question...
How do I deal with the large hole in the above hatch...
I was thinking of backing the hole with a piece of ply with waxed paper while I put down my first 1.5 oz mat on the inside of hatch! The smaller screw holes, I plan on backing with blue painters tape....
Any other suggestions for the large hole appreciated!
Only need to repeat the process on 3 more hatches (bow/anchor hatch, center console hatch and stern baitwell hatch!!!)
-Fred
Old 03-28-2012, 10:11 PM
ct9amr ct9amr is offline
Great progress in a short amount of time.
Glen
Old 03-29-2012, 07:46 AM
Thanks Glen...looking at your signature we have owned the same boats...!!!
Hard to get things done on the weekends so trying to take advantage of the longer days when I get home from work....
-Fred
Old 03-29-2012, 09:48 PM
Tashmoo2 Tashmoo2 is offline
Was your hatch completely flat? Just be sure when you put the new core in that it does not distort the original profile. You might lose the camber if you place weights on the ply wood to hold it down.
Old 03-30-2012, 07:43 AM
The hatch is completely flat..thank goodness..
I am going to place it on the garage floor when I layup the fiberglass and plywood core squares. Hopefully will get to it this weekend.
Thanks for the reminder!
-Fred
